Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
LQ4 alternator relocation bracket- 120 shipped
Old 09-17-2012, 09:22 PM
TurboZ28408's Avatar
Default LQ4 alternator relocation bracket- 120 shipped
Category: Accessories
Price: $120
Location (State): CA
Item Condition: Brand New
LS Engine?: Fits LS Engine
The tensioner and triangular bracket with the 3 spacers goes bolted to the lower driver side of the engine block (kind of where the alternator used to be). The alternator goes on top with the aluminum spacer and the other long steel bracket on the passenger side cylinder head.
good if you're swapping an iron block into your f-body because you cant use the factory ls1 brackets.
120 shipped. paypal accepted. verified
Thick wall pipe stand-offs CNC lathed
1018 1/4 Mild CNC laser cut plates
Heliarc Tig welded joints
Hardware included
uses your stock tensioner and stock altenator
** overall same construction but the bracket does have a different stand off for the lq4 to make it applicable., ***
Located in San Jose
Old 09-24-2012, 11:27 PM
tttttttttt
Old 09-25-2012, 08:14 AM
BMF_Racing's Avatar
Question
any pics installed?
Old 09-25-2012, 10:36 AM
this bottom bracket is in a modified form to fit the lq4, its got an additoinal leg that actually bolts up to the front cover as a mounting point and doesnt use one of the mounts shown
[IMG][/IMG]
Old 09-26-2012, 01:59 PM
ttttttttttt
Old 09-26-2012, 07:07 PM
Texhotrod593's Avatar
Do you have any pics of the belt on the tensioner? reason I ask is that it dont make sense why you would relocate the tensioner when the stock pulley is grooved... wouldnt it need a smooth pulley? Please help me understand that thank you
Old 09-26-2012, 10:12 PM
You remove the groove pulley and exchange it for the smooth on the idler
Old 10-22-2012, 01:18 PM
tttttttt
Old 10-24-2012, 12:48 PM
ttttttttttt
Old 10-31-2012, 04:42 PM
tttttt
Old 10-31-2012, 05:53 PM
Jadedbird's Avatar
Subing. Might need one of these for my lq4 this weekend
Old 11-14-2012, 11:04 AM
let me know
Old 11-23-2012, 01:37 PM
tttttttt
Old 11-25-2012, 02:33 PM
fastcars95's Avatar
How much for just the bottom bracket ?
Old 12-03-2012, 10:22 AM
tttttttttt
Old 12-03-2012, 10:47 AM
Br1_ss's Avatar
Doesnt the LQ4 tensioner relocates different than the aluminum blocks?
Old 12-03-2012, 12:05 PM
jakeb's Avatar
Is this designed around truck standoff or fbody stand off?
Does it use the fbody power steering pump (looks like it does)...
So is the tensioner the first item in the belt path?
Old 12-03-2012, 12:29 PM
i used the ls1 bracket and modified it to bolt to the front timing cover due to lq's not having a bolt hole where ls1's do. uses the timing cover bolt and the 2nd mount location. uses all factory f-body pumps etc
Old 12-03-2012, 08:26 PM
tjb406's Avatar
so it is fbody spacing not truck spacing?
Old 12-04-2012, 02:14 AM
correct its made for an F-body with an iron block setup.. there's no need for an alternator relocation on an actual truck setup with truck accessories because the alternators already relocated. This brackets purpose is to relocate the alternator to make room for a turbo setup.
Quick Reply: LQ4 alternator relocation bracket- 120 shipped
