What Hp i can expected from my Front Mount
Old 09-18-2012, 02:52 AM
1loudTransAm's Avatar
Default What Hp i can expected from my Front Mount
I have a 2001 T/A auto with a 3800 stall.
Stock 346 LS1
LS6 Cam
102mm Fast Intake Mainfold
with a TC-78 Turbo Front Mount w/ intercooler 8psi
Full Exhuast & a Tune
what hp will i be around?
and What can i do to reach 12psi. in Mods?
Old 09-18-2012, 09:04 AM
HRHohio's Avatar
at 8 psi, I'd say borderline 505 rwhp
to get to 12 psi, you gotta go forged pistons/con rods, and probably heads.
Old 09-18-2012, 09:26 AM
DavidPHumes's Avatar
I disagree with the second statement. A stock shortblock should be just fine for that, provided the tune is spot on.
FWIW I wouldn't recommend the TC78 for that CI. Preferably something like a 7675 with a bigger turbine wheel. It will work obviously but you'd be leaving quite a bit on the table IMO. Others might disagree with that statement.
You'll also want a different stall converter for sure.
Old 09-18-2012, 12:16 PM
whats wrong with the stall i have?
Old 09-18-2012, 01:38 PM
It's too high. The converter is an integral part of a turbo car and just any converter that was in your car before is unlikely to work well with a turbo system.
Old 09-18-2012, 02:09 PM
Sweet_SS's Avatar
How high would you go? My SS3600 works just fine and I think his will too. It's perfect I think. He'll be into boost when he hits his stall. Another note, you should be able to make over 500RWHP reliably...given the tuner doesn't get aggressive on a/f and timing.
Old 09-18-2012, 05:49 PM
Captain Double Post
BOBS99SS's Avatar
Our buddy made close to 700 on e85,think it was 695 on kill,you should make decent numbers,should have no issues getting well over 500, imo i would swap the fast for a ls6 and save the money,thats just what i would do,maybe start saving for a forged short block so you can really let her eat
Old 09-18-2012, 09:39 PM
thanks for you guys info, i have 2 stalls a 3600 from Rev Max and 3800 from Circle D "Currently in Car". i might save the money on a fast intake for a build bottom end, which the price are alike. i want to do a save tune with a 11.1 A/F if thats good.
My currently tune is 11.1 A/F and timing at 18.
Old 09-18-2012, 09:41 PM
and does anyone know a good tuner on ls1 in florida, i heard a guy in Tampa is azaming at tuning ls1 N/A and turbo ls1's.
Old 09-18-2012, 09:48 PM
oddwraith's Avatar
Keep that Circle D in there and make sure you don't go cheap on a tune. I don't know why someone said you'd need to swap it out . I can't wait to go that route on mine . Sounds like a decent setup so far man...
Old 09-18-2012, 10:26 PM
thanks. im not going cheap on a tune, i going to find the best dyno tunes on the market
Old 09-18-2012, 11:45 PM
itsslow98's Avatar
I believe fasterproms is in Florida.
Old 09-19-2012, 10:44 PM
i learn my lesson in the past from other bad tuner in my area. i heard of a good LSx tuner in tampa and that looks like him. thanks. hoping the stall can handle the 500rwhp power, cause i think the spec on them is handling 550 - 600hp
Old 09-19-2012, 11:22 PM
T76s10's Avatar
dave is affraid of the bigger turbos
Old 09-23-2012, 04:29 PM
Tampa Tuning's Avatar
Default Tampa Orlando Dyno Tuning Camaro Corvette CTS-v GTO GM Trucks performance tuning
If your looking for a calibrator that doesnt cut corners and cheat your car's performance, reach out for the Tampa Tuning
You'll love the way your car performs when we've completed the calibration process. The problem I see locally is the same tune being used over and over for differant applications then trying to make it work, and trying to rush through as many jobs as possible just to make a buck.
ALL TO MUCH, I see guy's cars drowning in fuel to keep knock retard down, rather than understanding how, why and when KR occurs to calibrate the tune to correct the problem before the onset and make the car perform its best.
Your vehicles calibration should start with your injectors, and when we fix tunes, I see when guys change injectors, the tuners dont have to proper flow data to write into the calibration. Im not just talking about changing the flow table Vs KPA that my kids can do. You have to change the offsets, pulse adders, and injector timing boundary and more so the fuel burning cycle begins properly.
You can send me an Email to set up an appointment at:
Tuning@TampaTuning.com
or call
813-727-8720
Thanks
Phil Owner of Tampa Tuning
www.TampaTuning.com
Old 09-23-2012, 10:31 PM
im running 13.1 A/F on idle and 11.1 on WOT. its very rich. burning 12mpg on the city and 19mpg on the Hwy, for only being a 228R Cam car
Quick Reply: What Hp i can expected from my Front Mount
