General LSX Automobile Discussion Non-technical LSX related topics.
detonation after new screened maf
Old 09-19-2012, 09:02 AM
clean98z-28's Avatar
Default detonation after new screened maf
I just recently purchased a new screened maf to replace my descreened one now. the car detonates like crazy loses all power up top i always run 91 octane its all we got in az no 93. The maf is from a 99 vette dont know if that makes a difference
Old 09-19-2012, 09:20 AM
thunderstruck507's Avatar
Have you tried putting the old one back on or unplugging it completely?
Old 09-19-2012, 09:29 AM
Im going to try the old one when i get home. But wont unplugging it make it throw a code and run like crap?
Old 09-19-2012, 12:02 PM
Endrance's Avatar
Yes, it will throw a code, but no it will actually make your car run like a god.
Old 09-19-2012, 01:13 PM
Unless something else is really wrong unplugging it will send the car into VE only mode which is a table programmed by GM to estimate air/fuel to make the car run.
It will set a code for MAF failure but should run decent. If it runs like crap with either the other MAF or MAF unplugged, you need to get someone with a good scanner to help diagnose the cause.
This is all assuming you didn't just get some crap gas...it happens and no brand is safe.
Old 09-19-2012, 03:13 PM
I'll throw the old Maf in and start it unplugged . Really appreciatehe help guys.
Old 09-19-2012, 03:23 PM
astro11271984's Avatar
Arent the vette maf 85mm i thought you had to get tuned witg diffrent tables if you go bigger
Old 09-19-2012, 03:30 PM
That is on newer vettes its from a 99 same size as my stock one .
Old 09-19-2012, 04:15 PM
Well ran normal with it unplugged . Still had a light detonation though.
Quick Reply: detonation after new screened maf
