1K whp Build - 10 bolt rear FTW
Old 09-19-2012, 10:08 PM
273sunsetZ's Avatar
Default 1K whp Build - 10 bolt rear FTW
This thing should be serious, but it's questionable how long the 10 bolt will last once we get in the 20-25psi boost range. I've been 6.5 @ 111mph with this rear in the 1/8 (previous setup in sig) and wondering what the record is with an F-body with stock suspension 10 bolt etc, anybody have a clue? It's at the point where theres paint cracks down the rear 1/4's next to the character lines so i don't plan on too much action this fall without sub-frame connectors at the very minimum.
These 2 are from before the build
Old 09-19-2012, 10:50 PM
buick_lsx's Avatar
Slow!
Old 09-19-2012, 11:01 PM
SSmoken's Avatar
what 60ft's? mines taken 1.45
Old 09-20-2012, 08:06 AM
got-a-ls1's Avatar
i beat the **** outta my 10 bolt with ~600 rwhp on the street for 4k miles with the turbo t56 twin disk and a **** load of 1.60 60's with the auto the past few years. quiet as ****.. i put the dana60 in while the 10 bolt was still good. i dont think they get enough credit lol
Old 09-20-2012, 08:10 AM
Moderator
denmah's Avatar
my friend has cut 1.42 60fts on a 10bolt.
225 shot on a ls1 4l80e trans.
Old 09-20-2012, 08:12 AM
helga203's Avatar
What head gaskets are you going to run?????
Old 09-20-2012, 08:25 AM
dschmittie1's Avatar
I went 10.5 @ 137mph on a 10 bolt M6 and Procharged. I dont remember the 60' though. Never broke the gears. The posi died though
Old 09-20-2012, 11:23 AM
robsquikz28's Avatar
I had over 100 1.4x short times on mine.
Old 09-20-2012, 02:17 PM
98BLOWNZ28's Avatar
I needed to read this. lol. gives me hope on my 10bolt for the new power i have coming.
Old 09-20-2012, 02:35 PM
Sweet_SS's Avatar
Good post and in for answers. I'm on a stock 10 bolt and suspension as well lol
Old 09-20-2012, 02:56 PM
StangBanger317's Avatar
I grenaded mine in an M6 with 408 to the tires. Lol
Old 09-20-2012, 03:43 PM
milkplus's Avatar
This thread is made out of pure tiger blood.
What gear are you running? If it's a 4.10, you're already on borrowed time. On stock gears where the pinion is larger, I can see the 10 bolt possibly making a full pass if you nurse it out of the hole.
Old 09-20-2012, 06:00 PM
427's Avatar
I ran a 10 bolt with good axles in 1973 Fbody, not sure if that is the same axle. It has 8.5 inch ring gear in those cars. I ran 360ci gen 1 with single stage nitrous and 3 speed auto. It would 60 between 1.20-1.25 and ran 8.2X@ 165-167 at 3200#. That axle is pretty strong if you weld the tubes into the center section and add a spool.
Kurt
Old 09-21-2012, 04:17 AM
1toofastlt1's Avatar
These newer f-bodys run a 7.5 inch 10 bolt. It's the ring and pinion that blow out most of the time
Old 09-24-2012, 11:56 AM
273sunsetZ's Avatar
it cuts consistent 1.5's then hauls the bacon after the 60ft
that's not bad at all, especially if he's spraying out of the hole
LS9's
Thats rolling out, mine went 10.07 @ 135 last year before i had a good fuel system. It kept going lean at the end of the pass so i had to let off about 60-80 ft before the traps.
haha my 10 bolt is on crack. I have a vid on youtube of racing a terminator from a 30 and blowing the tires off at around 70 and having to let off. search JRStephens21 on youtube and you'll see some 10 bolt abuse
LOL this thing was making 620whp for about 8 months until i cracked the block this spring, 6spd + 10bolt = fail
tiger blood and unicorn ****.
It's a 3.73 gear, i'm going to do my best to ease it out of the hole and roll out after the 60ft
Kurt
no idea if they are the same axel, but anything over 150mph with a 6spd is moving.
Old 09-24-2012, 04:48 PM
RacerXLs1's Avatar
Did I read right no frame connectors? Man there like a $100'bucks lol. I didn't have the ***** too push mine...
Old 11-11-2012, 08:04 PM
273sunsetZ's Avatar
You read correct. Might be time for some small chassis/suspension mods
Old 11-11-2012, 08:08 PM
273sunsetZ's Avatar
Build is done
http://i41.photobucket.com/albums/e2...8C0BAF2ECB.mp4
http://i41.photobucket.com/albums/e2...30DE70EA4E.mp4
Quick Reply: 1K whp Build - 10 bolt rear FTW
