General LSX Automobile Discussion Non-technical LSX related topics.
help 2000 ls1
Old 09-20-2012, 10:13 PM
mappy's Avatar
Default help 2000 ls1
Recently did a cam swap and now I got missing and smoke when under load runs fine a idle I checked the coils they are all good but I have one oil soaked plug
Old 09-20-2012, 11:30 PM
slikrider20's Avatar
I think you answered your own question.
Old 09-21-2012, 06:43 AM
garygnu's Avatar
do a leak down test .
Old 09-21-2012, 05:09 PM
mappy's Avatar
But id like to know the cause of the oil soaked plug and I will try leak down test but will that tell me if the problem is in the head or baf rings
Old 09-21-2012, 05:26 PM
JaYZeig's Avatar
valve seals
Old 09-21-2012, 06:41 PM
mappy's Avatar
You really think so it smokes at all rpm and is missing
Old 09-21-2012, 09:56 PM
garygnu's Avatar
at first I was only thinking broken rings,but a bad seal makes more sense after a spring change.remove valve covers and inspect the springs and seals of the fouled plug cylinder .a valve stem seal mite have come loose and is not sealing the oil from the valve guide.
Quick Reply: help 2000 ls1
