rocker play after new head and cam intstall helppp
got a 2003 6.0 liter lq4 i just put a new blower comp cam in it a st of new trick flow 220'2 a set of yella terra 1.7 ratio rockers.. just got done gettting the cam degreed and now when i rotate the motor over when the lifter is on the low side of the cam there is a ton of play at least a 1.8 if not 3/16 of play between the the rocker and the valve. any one have a clue why? im using a stock length push rod. im thinking the lifter is bleeding out oil and its not being able to pump back up since the motor hasnt been ran in a few months and theres no oil in the motor.. so any thoughts guys???
what i thought but the amount its missing the valve by a lot . think is more then a longer push rod will fix will the lifter bleed out?
thanks guys was gonna check the length anyway im waiting for the checker it just seemed like a ton of play so ill try a push rod tool when it comes monday and let you know what i fond
thanks
thanks
