General LSX Automobile Discussion Non-technical LSX related topics.
alternator wire
Old 09-23-2012, 01:11 PM
98z8uup's Avatar
Default alternator wire
I need help. I broke the wire to the alternator plug. How can I fix this?
Old 09-23-2012, 01:34 PM
Orange Juice's Avatar
Is it broken right at the plug?
If so there is a tool that will pull the connector out and let you insert a new one. If there is enough wire you should be able to just splice in a section using shrink wrap around the joints.
Old 09-23-2012, 01:38 PM
98z8uup's Avatar
It's broke at the plug. Where can I get the tool from?
Old 09-23-2012, 02:35 PM
99Bluz28's Avatar
JEGs has the #10769 Weatherpack Connectors tool kit for about $10
Old 09-23-2012, 03:44 PM
98z8uup's Avatar
I need this dome today so I can go to work on tomorrow. I will try summit.
Old 09-23-2012, 04:45 PM
Chawlz's Avatar
if you need it done today then probably need to check junk yard or try to connect wire directly to alternator without plug (temporary obviously). mine is just 1 wire...
Posted from LS1Tech.com App for Android
Old 09-23-2012, 06:57 PM
98z8uup's Avatar
Thanks for the help guys.
Quick Reply: alternator wire
