Wiring for Alternator with holley system
Old 09-23-2012, 03:57 PM
protracracing's Avatar
Default Wiring for Alternator with holley system
I am doing a 5.3 turbo in a fox body mustang with a truck alternator.
I will be using a holley standalone efi system.How do I wire the alternator?
Thanks
Dennis
Old 09-23-2012, 11:44 PM
soundengineer's Avatar
2 options..
buy a one wire alternator...
I suggest getting one from powerbastards.com
or...
you need to run any 12v igntion on source to it and run thru a small light bulb first
Old 08-05-2014, 07:15 PM
chuckd71's Avatar
Old thread but thanks for the info.
Old 04-04-2017, 06:07 PM
TurboChapman's Avatar
Reviving a old thread here. If I use the Holley Pigtail with resistor Part Number 197-400 can I just hook that to any 12V Key on Source?
Thanks
Old 04-06-2017, 10:01 AM
Project GatTagO's Avatar
Received 1,388 Likes on 877 Posts
Thanks
Yes. I am using the same pigtail with the Dominator ECU. I actually created a 12+ output on the Dominator and connect that to the alternator through the Holley pigtail. I also added a terminal to the S post and ran that to the main power distribution point. This is optional, but desirable.
Andrew
Quick Reply: Wiring for Alternator with holley system
