set up for ms4cam
set up for ms4cam
i have a99camaro i these sre the planned mods i bought an ms4 cam kit including push rods and precition double springs and timing chain set and ported milling oil pump and
Racing fuel pump 80mm throutel body 1 7/8 lt headers ls6intake msd wires tr55 plugs
New fuel filter knn Air filter borla exhust cat back. Stock ls1heads. Now where am from
We use bad pump fuel.i think its a 95 octain. Planing to tune it be Efi live with a local tuner
? I spoke to the tuner he told me that the estimat whp is arround 380 to 400. I was wondering do u think that these whp figures are low or right he also told me that this set up will give me low end since iam using a 6speed manual transmition now i have no choise of changing this cam since i already shipped the parts over see,s i was also wondeing how much rpm can i rev limit this set up can i go up to 7000 or is that to much
? Can i inject 150shots of nitrouse or is that too much keeping in mind i have a stock bottom end this engine is not so old it came out of 2006 lumina ss wich is an australyan car i am planing to smoke some supra,s to keep the american muscle raised up. My events ate good so far i also own 2 fierbirds but they wherr built through a friend of mine
One with an lsx 454 and the other is a head cam ls1. This would be the first car that i build of my choice so i just need ur guys idea and help.
that cam you should be making 420rwhp-450rwhp and that cam is all top end, you might get some cam surge depending on the tune, and yes you can take it to 7000rpm if you like
I've heard a lot of good and a lot of bad on the magic sticks...what duration and lift is the cam set at?And in my opinion, I would find someone with a hp laptop tuner,unless you can afford the dyno time.
What motor/platform is this built from? Depending on the platform you may also need larger injectors. You will also need EFILive or HPTuners in order to tune it correctly.
I would also recommend looking at an intake + 92mm throttle body.
Make sure the pushrods are measured properly using the old compressed head gaskets especially if you are using solid roller lifters. A pushrod measuring tool is not expensive and will be worth the investment.
Sorry u guys for my bad English I really apologize since English isn't my first language
That's why a choose this fourm cause I know Americans are more friendly
And helpful I really apreciate it help. So I see u guys sugested 4.10s .
But why . Cause am planing on street races where am from we roll 45mph
Up to rev limit of 5th gear. And . And some one mentioned I should Chek ptv
Do the valves with this set up have tendency of touching. And yes I'll dyno tune
The car with efi live. If am Gona go with bigger injectors what brand
And size should I go.? And can I shoot 150 nitrouse . Again sorry guys and
Thanx for taking the time to go through this thread.
And helpful I really apreciate the help. So I see u guys sugested 4.10s .
But why . Cause am planing on street races . Where am from we roll 45mph
Up to rev limit of 5th gear.. And some one mentioned I should Chek ptv
if you are roll racing, then use a 3.42 or 3.73 gear... check PTV just to be safe. Get some 42 lb/hr injectors. 150 shot of nitrous will be fine.... even 200 shot will be fine.
LS1TECH & Trucks Sponsor
The MS4 measures anywhere between .065"-.070" on clearance on the intake. While this is close it will definitely clear. We have verified this countless times on the engine dyno as well as a chassis dyno. Keep in mind this cam is meant to be a max effort setup.
