LS1 Engine Upgrades in 68 camaro
Old 09-24-2012, 12:39 PM
Stilo's Avatar
Default LS1 Engine Upgrades in 68 camaro
I have been building this 68 Camaro for over 2yrs Pro touring style but more curiser and hit the autocross and roadcorss maybe 2-3times yr and im at the point where i decided to upgrade my LS1 why not rite!
The LS1 is still stock but i have been buying parts for a few months so far this is what i already have.
Engine/Trans - 1999 Camaro SS LS1/4L60E 80k miles
Rear end - 1974 Nova 10 bolt 8.5 posi w/ 3.73 gears
BRP Muscle Rods - Full length headers
MagnaFlow - Full 2.5" Staineless Steel w/X-pipe
Marathon - Radiator
LS6 Intake
243 Heads (stock)
TSP 228R Cam (110 LSA), TSP 7.400 Rods, Pac 1218 springs
LS6 Oil pump (stock)
ProGear Adj. Timing chain/gear set
TCI - SSF 3500 Stall Converter
MSD 8.5 spark plug wires
Things I still need -
Engine Tune (Frost or Dyno)
Trans Cooler IDK what size
Hydro boost brake unit
ALL the gaskets and new belt
DRIVE SHAFT
Under Drive pully (Not sure on this yet)
MAF Sensor
Harness
Fuel lines 3/8"
O2 sensor
Other random ****
I think i have everything covered let me know what you guys think i should add and how much RWHP this combo will be putting down.
Old 09-24-2012, 01:17 PM
mark21742's Avatar
Sounds like a good solid combo and your car is beautiful. Not sure how you plan to wire it, but I used the how to guide on lt1swap.com...gives you all the pinouts and color codes to make a stock harness into a standalone system.
Old 09-24-2012, 01:24 PM
Stilo's Avatar
Thanks, i do plan on just modifying my stock LS1 F-Body harness i just hope i have enough slack to mount the CPU under my dash behind my fire wall some where out of sight and wrap it in a nice woven wire loom for show
Old 09-24-2012, 02:18 PM
mark21742's Avatar
On my GTO with the stock harness I had enough wire without cutting to move it from under the hope to up behind the gauges in the dash
Old 09-25-2012, 11:12 AM
Stilo's Avatar
Im trying to be over +400 RWHP i dont think it should be a problem with a good tune any one running a similer combo?
Old 09-25-2012, 07:00 PM
mark21742's Avatar
You should be close with that setup....if I were you I'd clay the heads to check your piston to valve clearance and then mill the heads down to bump your compression up a little while not taking too much off to where you run your ptv clearance too tight....also I like the .040" mls gaskets to keep the quench nice and tight.
If you know what your doing you can also go in and do some porting on the heads to get them flowing better.
Old 09-26-2012, 10:40 AM
beach cruiser's Avatar
Fwiw, I mounted my ECU in the area were the dash speaker was above the vent controls. I ran the harness through the tunnel just behind the firewall and it all worked out fine. Nice car BTW! I plan to RR and AutoX mine, I went with a Fluid Damper 10% UD pulley.
Old 09-26-2012, 11:05 AM
Stilo's Avatar
Cool so i think i should have enough slack to mount it somewhere under my dash, How did you like the 10% UD pully im still debating on getting one not sure if a 10% or 25% was it an easy upgrade can i just do it later or should i do it all at once?
Old 09-26-2012, 11:06 AM
Stilo's Avatar
Im getting a 3angle valve job done on them and light hand porting
Old 09-26-2012, 12:48 PM
mark21742's Avatar
That should work....concentrate work around the valve guide, take out the flashing, then blend everything as best you can
Old 12-12-2017, 01:42 PM
Stilo's Avatar
finally getting back to this build a few yrs late but its coming back
Old 12-12-2017, 02:40 PM
tug686spd's Avatar
Glad to see your back on the project. Progress pics are alway enjoyed so let's see them. If you only knew how long my 68 has been down you'd feel good about yourself for sure.
Old 12-12-2017, 03:03 PM
DANOZ28's Avatar
your 243 heads are good but i'd send them in for a stage 1 or stage 2 valve porting job. ls2 timing chain (50% better than ls1). imo i'd go with an ls1 tech sponsor stall over tci. just my one cent.
Old 12-13-2017, 11:43 AM
Stilo's Avatar
I bought the car in 2010 and drove it around for 2 months before blowing it apart, last time i worked on it was late 2011 and ive worked on a few swaps since so now i have the knowledge to finish it. I will post pics soon
Old 12-13-2017, 11:45 AM
Stilo's Avatar
Unfortunately i had all those parts installed yrs ago and now i just want keep moving forward and get it on the road, the heads where resurfaced and had a multi angel valve job, its just going to be a good cruiser i can beat on from time to time.
Old 12-26-2017, 12:03 AM
Stilo's Avatar
Mocking up everything
Test fitting
Old 12-26-2017, 02:36 PM
JoeydbCamaro's Avatar
Nice!! Where did you get the blocking plate for the two outlet ports at the waterpump? These ports go to the inside radiator
Old 12-26-2017, 03:13 PM
Received 3,021 Likes on 2,352 Posts
Joey, there is no blocking plate on the water pump for the heater core. I see two open holes.
Old 12-27-2017, 12:27 AM
Stilo's Avatar
Mocking up all the body parts
Old 12-27-2017, 12:29 AM
Stilo's Avatar
I actually tapped and threaded the ports on the stock pump, I will end up using stainless steel plugs
Quick Reply: LS1 Engine Upgrades in 68 camaro
