EGR AIR Delete?
EGR AIR Delete?
I pulled off the EGR and the AIR systems on my car and was wondering after blocking off both systems properly, will it still throw a code? Also do I need a tune after this? Dumb question I know, but Im sure there are more out there thinking the same thing. Thanks guys!
Yea u will c gain and good tuner tweak every lil bit of power out of the car if u have any other mods waiting to install ide do them before tune so u can save the cash and tune it once
In truth will there really be all that much of a gain from an LS6 intake? And isnt the opening for an LS6 85mm and the LS1 throttle body is a 78mm... So in ignorance I ask this... Would you not also need an LS6 TB...?
Throttle body is the same. I would be patient and buy a LS6 intake on the cheap. There are a lot of over priced ones out there. I got one for $200 and one for $250 and one for free. They are $500 new. They are well worth the cash. You can port your own throttle body with basic mechanical skills and a good metal die grinder bit.
