Heads for boosted LS1383 stroker?
Just wrapping up the engine build for project Judas(Audi RS6 plus LS still AWD)
The 2004 GTO ls1 suffered a bit of an issue due to a failed fuel pump at high rpm. After this I decided to build the motor, it now has a scat 383 striker kit and swaintech coated pistons. Compression ratio is now 9.5:1 f rom custom Mahler pistons. It is also getting a pair of rear mount gt3076 turbos with boost up to 20psi.
My question is wether anyone has a suggestion for aftermarket heads. CBC ports and chamber, big valves and dual springs, ti retainers etc (high rpm motor). Gasket recommendations would be appreciated too.
LS1Tech Premium Sponsor
Here is a link to our PRC 227cc cylinder heads, they would be great for your boosted setup:
http://www.texas-speed.com/p-1163-pr...der-heads.aspx
With that kind of boost, I would recommend a head stud kit, and cometic cylinder head gaskets
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Those do look like the business. Reading the specs it mentions for use on stock cube motors with small chambers for extra compression. Given my motor is a stroker 383 is this the correct head for my needs?
We sized the pistons for 9.5:1 cr with the stock 04' GTO LS1 heads, off hand I cant remember the combustion chamber cc we measured.
I have an ARP head stud kit already but need to get gaskets so will take your advice on those thanks.
What is the typical lead time on these heads?
Timmmy
Those heads are setup for your bore size rather than your cubic inch. They will work great with your application, and we can setup the cc of the combustion chamber to match the stock 68cc head that you had before, so that you can run the same compression.
__________________
Whats the average lead time on a set of heads like this?
If we don't already have them in stock, then usually we quote right around 2 weeks!
__________________
