Z/28 EPS Cam 1/8th Mile Times
Old 09-27-2012, 05:42 PM
Camaro Z's Avatar
Default Z/28 EPS Cam 1/8th Mile Times
Went to the local 1/8th mile and ran a new best. DA was around 1200. Below was my best run:
1.62 60 ft.
7.47 ET
94.02 MPH
I had four runs in the 7.40's and 5-6 runs in the low 7.50's. The car consistently has 60' times in the 1.6x's. I was power shifting on these runs. I would really like to make it to the 1/4 mile soon. I think I'm well in the 11's at around 119-120 (ran 11.8 @ 117 last year without powershifting and in poor air). This car dyno'd at 385 rwhp, which seems to be a pretty conservative number at this point.
Mods:
EPS 230/234 .600 .602 112+4 LSA
Stock Heads
LS7 Clutch
LS6 Intake
SLP Lid
Longtubes
ORY
3.5" Cut-out
Underdrive Pulley
4.10 Gears
Girdle
10-Bolt
Full Weight (Minus spare tire and drag wheels)
Below are a couple shots of the car:
Drag Setup (On the car all summer lol)
Street Wheels
Idle:
Old 09-27-2012, 07:26 PM
Footlead's Avatar
Good Looking Car !!!!!!!!!!
Old 09-28-2012, 11:02 AM
Camaro Z's Avatar
Thanks man, I haven't done much of anything appearance wise for a few years now. I still really like the look, especially with the drag setup.
Old 09-28-2012, 11:37 AM
sokr915's Avatar
That sounds niceeee
Old 09-28-2012, 11:41 AM
Zmg00camaross's Avatar
Should be 11.5s or so I think. How are you launching the car?
clonedws6's Avatar
Love it big time!
Old 09-28-2012, 12:03 PM
Beave's Avatar
Very nice! I just want to say thanks btw! Over the summer building my new motor i came across that same video and lead me to order the same cam lol. Im running pretty much the same as you but im in an auto car on 17" TT2's. Hoping to get some drag wheels and some suspension work (bone stock suspension) and hit some low 11's. Mine went 11.81@117 and the 1/8 mile was 7.57@92 with a 1.7 60ft.
stumprrp's Avatar
Beautiful car man. 94 in the 8th should be around 118 on the big end i would imagine as my old car did that and trapped around 118.8
Old 09-28-2012, 01:19 PM
Camaro Z's Avatar
Thanks for the compliments
I'm running it up to around 5K and slipping it hard out of the hole. I try to slip it just enought that it doesn't bog down. Seems to work very well and I have improved A LOT since I first started tracking the car. The clutch and rear end probably have 100 passes on them when the car had bolt-ons and around 50 since the cam swap.
Thats awesome! Looks like yours is running very well also! I was a little disappointed with the dyno numbers mine made when it was first tuned. I kept telling myself it's just a number, but when I went to the track with it I was and am still very happy with how it runs. I beat a lot of cars that I shouldn't and it's a ton of fun catching guys off gaurd when they ask what is all done to the car.
That's about what I was thinking. I'd be happy with anything 118 or over. The M6 pulls pretty good on the top end. I was gaining 25 mph over my 1/8 mile trap speed the last time I was at that track and I was trapping 92 in the 1/8, 117 in the 1/4.
Originally Posted by sokr915
That sounds niceeee
Thanks man
Old 09-28-2012, 01:21 PM
Beave's Avatar
Yeah, i learned a long time ago to not worry about dyno numbers. Track number dont lie lol. I didnt dyno my new setup, just street tuned and it runs just what i thought it would.
Old 09-28-2012, 01:35 PM
stumprrp's Avatar
Thats true, the car i referenced was an auto. Car moves. When i called Geoff when almost buying an M6 ride he recommended that same cam you have.
Old 09-28-2012, 03:49 PM
Can't believe the 10 bolt is taking the abuse lol. This gives me hopes for my lighter more gear bigger eps cammed car lol
Old 09-28-2012, 04:45 PM
Camaro Z's Avatar
Get yourself some soft bias ply tires, don't dump the clutch, and give it hell! lol
Old 09-28-2012, 05:09 PM
Has Hoosier qtp on it with 4.56 gears ran 7.4 with a hotcam and 11.6 at 117 mph. So the larger eps and fast intake and a bunch lighter hoping for the best
Old 09-29-2012, 12:54 PM
Camaro Z's Avatar
Sounds like your car runs good!
Old 09-29-2012, 12:58 PM
Camaro Z's Avatar
Went to the track last night and ran a new best in the great weather (DA 685). So close to a 1.59 60!
Old 09-29-2012, 07:22 PM
Kingc8r's Avatar
When punching in your 1/8th times in a calculator it says your 1/4 times should be 11.65.
Your car sounds and looks damn good. I look forward to seeing your actual 1/4 results
Old 09-30-2012, 10:43 AM
Camaro Z's Avatar
Thanks man, it will probably be next year before I make it to the 1/4 mile track.
I plan to make my own SSRA this winter and possibly move to E85 (injectors/fuel pump). I'm keeping it full weight and I'm going to keep pushing the 10-bolt as long as it holds!
Old 09-30-2012, 11:36 AM
Kingc8r's Avatar
Sounds good. Keep us updated
Old 12-30-2012, 08:12 PM
Camaroking1996's Avatar
Great times! You on 241 or 243 heads? Car looks badass with the drag setup
Quick Reply: Z/28 EPS Cam 1/8th Mile Times
