1969 Nova LS3/Auto
1969 Nova LS3/Auto
Picked up an 1969 Nova from my buddy Travis. This was his car in high school and has been sitting in his garage for the passed 9 years. It had a 4 bolt 350 and TH350 before.
first time out of the garage since circa 04'
L92 got her stripped down with all the truck stuff off. time for a thorough cleaning of the block, removal of the heads, and LS3 conversion. going with a prosystems carb and 6LS box. cam is coming from LG motorsports.
hoping this is the end result
my L92 came with a 6L80E from a yukon, however it has a transfer case on it for awd.
anyone know where I could sell it and how much its worth ? has 36k miles on it. I heard the TBSS guys use them as a upgrade ?
MSD 6012, canton x body swap pan, and vic jr are here.
canton pan doesn't seem to be fitting with the oem windage tray, the rear to main studs seem to be hitting the back of the pan
I removed one of the heads last night and inspected the cylinder, they look great and show little signs of wear. though it does have low miles it looks as though the previous owner slacked on oil changes.
now taking them to my buddy TC's shop for inspection and some clean up work on the ports.
LS1Tech Sponsor
Dirty Dingo for mounts.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
For some reason I can't see the pics. Dirty Dingo is a good choice for mounts, though it's pretty easy to fab your own.
If you're serious about not wanting to go AWD (which I think would be pretty sick), hit the Performance Trucks side of this site and toss the TC on the classifieds there.
Good luck with the build. There's a ton of info in the x-body swap thread.
Got in some parts
Professional products balancer
Comp 921 spring kit
ARP head bolts
Ls3 head gaskets
Ls7 lifters
Ls3 front cover
Ls3 timing set
Waiting on my cam from LG
Comp 921 spring kit
ARP head bolts
Ls3 head gaskets
Ls7 lifters
Ls3 front cover
Ls3 timing set
