If you swap the bellhousings, will an LT1 4L60E work on a LS1?
Old 09-28-2012, 02:32 PM
Need4Camaro's Avatar
Default If you swap the bellhousings, will an LT1 4L60E work on a LS1?
Are there any differences besides the bellhousings?
Old 09-28-2012, 02:37 PM
Rick Speed's Avatar
You don't need to swap belhousing to make them fit. They both bolt right up the problem is the torque convertor.
socal's Avatar
yes, it's not the bell houseing it's the convertor spacer thats needed if your reusing your LT 4L60e this is what youll need or something like it
http://www.jegs.com/i/JEGS+Performan...01010/10002/-1
http://www.jegs.com/i/JEGS+Performan...01011/10002/-1
Old 09-28-2012, 03:04 PM
Im doing an LS1 swap and I believe I was delivered an LT1 transmission by mistake. Im most likely going to have to return it though. The Torque converter hits flexplate before bellhousing hits block and that spacer will make it worse. Any other ideas?
Old 09-28-2012, 04:34 PM
Rick Speed's Avatar
Maybe it popped out and is just not fully seated. You'll need to spin it and push in at the same time and it'll pop in another inch.
Old 09-28-2012, 04:36 PM
bad67ls's Avatar
converter isnt all the way in.
Old 09-28-2012, 04:54 PM
The converter or flexplate?
Quick Reply: If you swap the bellhousings, will an LT1 4L60E work on a LS1?
