Name that plug
Old 09-30-2012, 12:40 AM
71_bowtie's Avatar
Default Name that plug
Hello everyone, I've been lurking on the site for some time and finally need some help.
I'm not sure if I need this plug.
http://secure.flickr.com/photos/8806...in/photostream
http://secure.flickr.com/photos/8806...n/photostream/
It then runs into this plug
and into a splice then into these plugs http://www.flickr.com/photos/8806953@N02/8038176629/
Old 09-30-2012, 10:59 AM
Stu Cool's Avatar
Only your last picture is showing up. The first three go to my own flickr text only index. Maybe you have them restricted as to who can view them? I notice they are https which indicates secure versus the last one which is http.
Pat
Old 09-30-2012, 12:32 PM
71_bowtie's Avatar
Thanks Pat, I removed the s hopefully everyone can now view the pictures.
Old 09-30-2012, 01:07 PM
85MikeTPI's Avatar
what did the harness come from? If I had to guess, it's a power feed to a relay that services two systems. Do you have a wiring diagram from your harness? Find those 2 plugs on it and trace back to how and where they get power from.
Old 09-30-2012, 05:44 PM
71_bowtie's Avatar
It's out of a 99 silverado. There is also a pink wire coming out of the C2 (D9) going to the big square plug. Lt1 swap says that D9 is not used.
Old 10-01-2012, 02:55 PM
71_bowtie's Avatar
163 views and not one person has come across this plug?
Old 10-01-2012, 04:10 PM
85MikeTPI's Avatar
Do the 2 weatherpak plugs have any other wiring in them that connect to the PCM, or another connector, or is the entire harness standalone?
I wonder if it's something optional, like a brake-trailer towing adapter harness ?
Old 10-01-2012, 08:34 PM
71_bowtie's Avatar
So I looked at the back side of the big square plug and found the numbers 85, 86, 87 & 30. I then found those same numbers on a schematic saying that it all has to do with dual fuel tanks. Could that be true? I wouldn't think that a 99 silverado would have dual fuel tanks.
Old 10-01-2012, 08:54 PM
85MikeTPI's Avatar
Those are standard pin numbers for a relay, as I surmised above.
Any response to post #7 ?
Old 10-01-2012, 08:56 PM
the_merv's Avatar
It's a relay plug.. For what is the question.
Old 10-01-2012, 11:01 PM
71_bowtie's Avatar
The numbers I'm referring to are casted on the plug, not pin numbers.
The 2 weatherpak plugs have one red wire and one black. Red going to the square plug and black are grounds. There is one pink wire from the square plug going to the C2 plug position D9. There is also a tan wire from the square plug going to the red connector pin 3. LT1 swap says its a Fuel Pump Relay Control - Secondary. I'm going to take my chances and get rid of it. Don't think I need it for a standalone harness.
Quick Reply: Name that plug
