5 PSI with my set up. Need advice
Old 09-30-2012, 01:21 PM
DavidGXP's Avatar
Default 5 PSI with my set up. Need advice
Should I buy this and install it on my car? https://ls1tech.com/forums/ls4-perfo...l#post16769411
Current set up is:
5.3L
Pat G cam 218/222 113.5 .600/.600
TFS 205cc heads
10.8 CR 8.6 DCR
LS6 intake
3" into dual 2.5" exhaust.
Basically 3.73 gears
I would obviously need tunning and more fuel. Would this turbo work ok with my cam, compression and gears? I shift at 6500 RPM. I would like to step up to a inter cooler later in life.
Is it worth it or not?
Old 09-30-2012, 01:57 PM
PewterZCar's Avatar
I am not a fan of non intercooled kits. Yes you can get away with it, but the summers around here are way too hot. My IAT's would be insane. If you were to run this without an intercooler, You would need a meth kit, or an e-85 conversion. All of which cost as much or more than adding an intercooler to the turbo kit. Just something to keep in mind.
Good luck on your quest for boost. I know I'm enjoying it.
Old 09-30-2012, 02:07 PM
JohnS Z28's Avatar
for $2800 you can get a huron speed kit, which is intercooled.
Old 09-30-2012, 02:14 PM
DavidGXP's Avatar
The kit includes water meth injection. I will probably pass, since I am built for N/A
Old 09-30-2012, 02:16 PM
js2fst's Avatar
Pewter z car what part of lee's summit are you in?
Old 09-30-2012, 02:19 PM
o2camaross's Avatar
The more power you make NA the more power you will make boosted.
Quick Reply: 5 PSI with my set up. Need advice
