1500fwhp with magnafuel 4303?
Old 09-30-2012, 04:05 PM
ninetres's Avatar
Default 1500fwhp with magnafuel 4303?
Considering using this set-up:
sumped tank
-10 off sump/prefiler to pump
magnafuel 4303 with -10 supply
-10 feed
-8 return
I have seen it mentioned several times that a -12 supply to the pump is ideal. This is not really feasible with my set-up. Will the way I run it support 1500fwhp with twin turbos? Would I be better off running one of their MP-4101s?
Thanks.
Old 10-01-2012, 06:19 AM
PewterZCar's Avatar
what fuel? if you're using e-85 you may need 2
Old 10-01-2012, 09:35 AM
ninetres's Avatar
No, race gas. Shell URT Advanced.
Old 10-01-2012, 02:08 PM
ninetres's Avatar
Answer from magnafuel is no.... it will only flow 1300fwhp in my application (50psi base pressure with 20psi of boost).
Sounds like the 4101 is for me.
Old 10-02-2012, 11:27 PM
8 Second Truck Club
Blown06's Avatar
I doubt it would even do that.
Old 10-04-2012, 04:37 PM
LS1NOVA's Avatar
It should do 1500fw. Ive used one -12 fed 4303 to 1000rwhp on E85 on 45 base with 21lbs boost referenced. It was done at that point.
Old 10-14-2012, 01:35 PM
stevieturbo's Avatar
Do Magnafuel or any similar companies offer any flow data for such pumps ?
Quoting 2000hp is pretty meaningless when they claim that is n/a only
And a range of 20-120psi is also meaningless without flow data vs pressure.
Old 10-14-2012, 11:44 PM
8 Second Truck Club
Blown06's Avatar
I haven't seen flow data quoted directly from them. Pretty ridiculous and I agree with you.
If you search, I started a thread to compare the 4303 with 3 255's. Third party posted flow ratings I believe.
Old 10-15-2012, 06:31 AM
It seems that what they sell as a 2000hp pump, in reality for a lot of users might only be a 1200hp capable pump
they really should make things clearer.
Quick Reply: 1500fwhp with magnafuel 4303?
