2011 Camaro stock rims on 2000 Firebird
Old 09-30-2012, 07:15 PM
FenixSS's Avatar
Default 2011 Camaro stock rims on 2000 Firebird
Hi, got a friend who's getting rid of his stock rims, I found that their measurements is 18x8.5 but can't find the offset/or lug pattern measurements. I currently have stock 16s on my 2000 firebird, would these fit? Will I need spacers or anything along with the new tires? Or are the patterns between the two incompatible?
Old 09-30-2012, 07:24 PM
1999transamls1's Avatar
I saw a picture of it, it ended up in cheesiest fbody thread, looks terrible, I'm sure you could find the picture using search
Old 09-30-2012, 09:06 PM
FenixSS's Avatar
I c, thank you very much
Old 10-01-2012, 07:26 PM
my bandit's Avatar
they are 18's? so are they the base v6 black ones with the lip? post some pictures since theres a few different types
Old 10-01-2012, 08:14 PM
bill12690's Avatar
They should bolt up, just know that the bolt pattern is just slightly different, which could possibly shear a stud (although very doubtful)
As far as offset, I'm not sure what it is on those wheels so they may stick out or sink into the wheel well. F-body bolt pattern is 5 x 120.65mm, 5th gen is 5 x 120mm, so like I said they're pretty close.
As far as what it'll look like, well... it'd be interesting. lol
Old 10-01-2012, 10:15 PM
Oh they are the black bare ones? I haven't seen those on a 4th gen. The ones I saw were the silver 5 spokes. I personally don't like the black wheels, try em on and if you like them, get them. Any idea what size tires are on the 18s? That may be another concern
Old 10-06-2012, 10:28 PM
69TA's Avatar
I have a set of wheels that were originally for a 5th gen
that I made to work on a 4th gen.
First off the hub bore on a 5th gen (smaller) is a different size
than a 4th gen (larger). So you will have to get it machined out
to fit on the 4th gen.
Also being that the wheel bolt pattern is not exactly 120.65mm
I like to run the lugs that have a non fixed seat, Mc Guards makes
some nice ones. Reason being that the lugs with the free spining
seat will mate up better in this set up and accomodate the little
variance of .65mm
They make a lot of baller wheels for the 5th gens.
Here is mine.
Old 10-07-2012, 01:09 AM
Mr.z/28's Avatar
variance of .65mm
Here is mine.
pictures of these on a 4th gen or its not true.
Old 10-07-2012, 06:33 AM
69TA's Avatar
Smile
Yeah i am trying to get tires for them and other things keep coming up.
Old 10-07-2012, 12:18 PM
CAL99SS's Avatar
I too have a set of 5th gen wheels. 5 spoke 19"s. I never wanted 19's. Just 18's but I dont have tires and would like to see these 19s on another 4th gen. Before even buying tires.
Quick Reply: 2011 Camaro stock rims on 2000 Firebird
