grinding/rubbing noise from rear
Old 09-30-2012, 07:41 PM
Sladester2's Avatar
Default grinding/rubbing noise from rear
Everytime I turn semi-sharp or when i loose traction and slide to the left I get this noise from the rear. Sounds close to the rear passenger tire. Anyone know what it is? I did have a loose sway bar if it could be anything to do with it.
http://www.youtube.com/watch?v=wG-92...ature=youtu.be
Old 09-30-2012, 09:17 PM
Sladester2's Avatar
Ttt it almost sounds like plastic maybe but I can't tell
Old 10-01-2012, 09:07 AM
Sladester2's Avatar
anyone?
Old 10-01-2012, 12:20 PM
Sladester2's Avatar
still looking for ideas..
Old 10-01-2012, 01:29 PM
eb110americana's Avatar
To me it sounds like one of the bushings somewhere. Just due to how close it seems, check the upper shock mount. The rubber isolators are fairly small and can degrade over time or get squished if over-torqued. That's just a guess though.
Old 10-01-2012, 09:05 PM
Sladester2's Avatar
I know it's a weird sound and it does sound really close tho. Sounds almost like plastic
Old 10-01-2012, 09:32 PM
Do you have the heater hose spring mod on your car? You could check the top of the springs too.
Old 10-01-2012, 11:06 PM
Sladester2's Avatar
I do not
Old 10-02-2012, 12:02 AM
94'BLKBRD's Avatar
Bump stops? or tires rubbing on quarter panels?
Quick Reply: grinding/rubbing noise from rear
