At what level did your heads lift?
I started to push some water after 24psi. I've been hitting around 30psi lately so this winter i'm going to try some ls9 gaskets. Already have arp studs but only tq down to 85 maybe i'll try to tq down to 90ish. I' already went through 10 gals of meth this summer. Over 1200whp
i have the regular 3 layer 5.3mls gaskets and arp studs no problems 20psi. well no problems ive noticed im taking this motor out here in a day or so ill check the gaskets... but always ran great
Timing plays a part in cylinder pressure too. You'll lift heads sooner with an aggressive tune.
I've only been to 11 psi on stock lq4 pistons, 70cc heads, ls9 gaskets, & arp studs. 21* timing, 93 pump & 100% meth. No problems yet
ok so stock head bolts makes sense. haha im so tempted to try the ebay studs cuz im switching to a l33 block and i need the newer style studs but they scare me and ill just buy the arps
I used one set of the ebay 1997-03 ls1 studs, and they were iffy torquing to 75ftlbs, not even ARPs recommended 85ftlbs. For ~700rw hp builds and lower I wouldn't hesitate to use them with a set of LS9 gaskets if the budget is tight.
Mine has forged pistons and rods, 3 layer mls, ARP studs, just ran it at the track at 23psi and 18 degrees timing and 12.0afr for 12 1/4 mile passes without issues but looking to make a little more power but upping the boost to around 28lbs and getting the afr back in the 11.7 range but dont want to kill it if I can avoid it.
MASS seller approved
18 psi on straight propane and so far so good. hurled ~4700 lbs to a 11.95 1/4 mile whatever that works out to for horsepower. Truck block with all stock factory assembled 225K mile motor.
just found out recently from mechanic i was seeping coolant , i,m guessing only at the track 144mph @4050 pds, 20psi, lq9 iron totally stock 241 heads, arp head bolts, cometic gaskets !!!! i was wondering where that coolant was coming from haha thought i had a leak in a hose somewhere !!! in getting 0.0850 thick deck heads and head studs with new setup now!!!!
