Which is the better cold air kit?
Old 10-01-2012, 01:20 PM
Fine408C5R's Avatar
Default Which is the better cold air kit?
I'm stuck between 2,the Slp flopack from Tsp with the high lid smooth below and k&n filter or the k&n cold air kit itself any big difference in the 2?..the Slp flopack is cheaper and already comes with the smooth below instead of paying $60 just for the below. The k&n is a little pricy, but was told you'll see better gains because of no restrictions.
Old 10-01-2012, 01:24 PM
Drew-Bot's Avatar
Well whats your budget? Also correct me if I'm wrong but the gains from the 2 are not going to be very much so I would assume it is all about your budget and your future plans.
Old 10-01-2012, 01:31 PM
Fine408C5R's Avatar
I'm guessing probably.. just speaking that the k&n fuel injection cold air kit would benefit me better down the road for headers true duals and head and cam swap.It might be pricier I'm just tryin to be logical but I have seen the flopacks on some h/c cars that will run guess it's really just a matter of preference.
Old 10-10-2012, 09:40 PM
2000z77charger's Avatar
If I had to pick between the two I'd go with the slp not a fan of the k&n design on this particular set up done some research on air intakes and I'm going to go with the ssra set up
Old 10-11-2012, 08:12 AM
ss1le02's Avatar
Get a real ram air kit like the SSRA
Old 10-11-2012, 10:03 AM
Element's Avatar
The smooth bellows is an appearance bit, it won't affect the performance one way or the other.
Just get a decent lid and run a paper filter, lots of people have issues with oiled filters screwing their MAF up, and the paper filter itself is a non-restrictive part; someone on here did a back-to-back dyno with and without a paper filter, and the power difference was below the resolution of the dyno.
Old 10-11-2012, 10:52 AM
}BlueFire{'s Avatar
Chris1313 ram air from speed Inc and a lid is all you need!
Old 10-11-2012, 11:31 AM
Sales1@Texas-speed's Avatar
Out of the two options you mentioned the SLP flowpac would be my choice.
Old 10-12-2012, 01:47 PM
2000PewterT/A's Avatar
I have the SLP Flowpac and I would prefer it over the K&N, never been a big fan of their products.
Old 10-12-2012, 02:35 PM
usnfenix's Avatar
cannot stress this enough OP, the smooth bellows is a nothing more than a way for slp to get more money. it does not give you the magical 5 hp it claims and if you really wanted it you could get some PCB pipe and paint it black and use that rather than pay 60 bucks for some overpriced garbage plastic.
i has the SSRA and it did actually work, i was happy with the results
this is true. CAI is commonly misunderstood. COLD air induction. CAI's for fbodys typically have their intake on the driver side, in front of your motor by the headlight. tell me how that air is any cooler then moving the intake to its stock position 1 foot to the left? its not. not by any ammount that will be worth the 160-300 bucks you pay. a true CAI draws from underneath the car, and as far out of the engine bay as it can get where air is actually cooler. for our cars i would go with a true ram air kit such as the chris113 or the SSRA, and get a lid ( a lid is a lid so no need to get picky on choice. slp is the cheapest) then seal the lid and let the SSRA or chris113 do all the work. its up to you OP but use your head and think about the two setups and which one actually makes sense.
Old 10-12-2012, 05:47 PM
z-maro's Avatar
I'm also very happy with my SSRA. Al is a great guy to deal with, and the quality is top notch!
Old 10-14-2012, 01:25 PM
Cra-Z Larry's Avatar
+1 on being happy with my SSRA!! Z28s have nothing under the airbox so it made a real improvement, 2-3 hundreths off my 60' and 2 mph. The Chris1313 wasn't out when I got the SSRA but posts indicate that it works well also. Choice is yours! Good Luck!! Larry.
Old 10-21-2012, 10:45 AM
spikeyoda's Avatar
where can we find the SSRA, and some information on it. I was just planning on going with the SLP system as well.
Old 10-21-2012, 11:54 AM
cranny's Avatar
http://item.mobileweb.ebay.com/viewi...id=35322867646
Quick Reply: Which is the better cold air kit?
