T6 s475 on 5.3 truck?
Old 10-01-2012, 04:02 PM
o2camaross's Avatar
Default T6 s475 on 5.3 truck?
There is a local guy selling a T6 s475 with a 96mm wheel and 1.32 ar housing. I will have to redo my hot pipes to run it which isnt too big of a deal. Right now im running an on3 76mm with a 65mm wheel and 1.0 ar housing. I know its a huge jump but how would yall think the bw turbo would work with my setup? So far Ive been 11.4 @121 with shitty air on 14psi. Set up is 5.3 with stock heads, TU1 cam, Ill be throwing a TBSS intake and TB on it, TH400, circle d 3000 stall and 3.42 gears. Weight is around 4200
Old 10-01-2012, 04:10 PM
Ferocity02's Avatar
Seems like it would take forever to spool.
Old 10-01-2012, 04:16 PM
o2camaross's Avatar
Yea thats what im thinking. but it will be good for the future engine. I wish someone who has run one before would respond
Old 10-01-2012, 04:31 PM
Grr
Grr's Avatar
throw it on with a spool valve and let it eat, it will spool alot slower but will more than make up for it, likely make more power at 1-5psi spooling slow than you are now at full boost.
Plus you will be up a solid 10+mph up top, do it man!
Old 10-01-2012, 04:43 PM
o2camaross's Avatar
You have a really good point there. Im going to do it. My roommate keeps puching me to do it too. how do those spool valves work and where would i get one?
Old 10-01-2012, 04:59 PM
Grr
Grr's Avatar
well if you can put it together and manage to leave 1" of lateral movement for the downpipe and IC pipe I would put it on there without a spool valve first. They are expensive but they flat out work, I did it with a home made setup back in the day BW S475 on a 6.0L with just a cam and it was similar to a PT7675 for spool but made crazy power, around 800whp.
Instead I would just get the converter restalled to a 3600. But if you do buy a spool valve it would be pretty much spot on with what you have now
Old 10-01-2012, 05:07 PM
a-low's Avatar
I believe forcedinductions has a t4 housing for that turbo.
Old 10-01-2012, 05:08 PM
ren987's Avatar
Even if it does spool to slow for your liking you can always put a different a/r housing on it and keep the 1.32 on the shelf for later on down the road! This thing is going to scream up top and it will help with your traction problems in 1st gear, but maybe not help in 3rd
dville_gt's Avatar
What are you going to do with the turbo, drag race, street race, road race? If it is an auto and you are going to drag race it I wouldn't worry to much. I have this turbo on a 6liter and it spools pretty quick, but not quick enough for a sudden roll on street race.
Old 10-01-2012, 05:11 PM
o2camaross's Avatar
yea just looked them up and they are $600!! no thanks lol. Dont really want to take the stall out either lol.
Old 10-01-2012, 05:14 PM
o2camaross's Avatar
Mainly for the street but I go to the track whenever I can, thats what I built it for really. I think Il just go ahead and get it. Now when Ill be able to build a new hot side idk lol
Old 10-01-2012, 05:15 PM
a4ls2goat's Avatar
I would do it. It'll make more power than the on3 76 anyday.
How much weight reduction do you have that your truck is so light.??
Old 10-01-2012, 05:18 PM
Verz's Avatar
I agree with getting a diff turbine housing for now and holding on to the current for your future/bigger engine.
And well if you do it and need a quick sell on the on3 I might know a guy with another white Lsx truck needing a turbo
Old 10-01-2012, 05:21 PM
o2camaross's Avatar
Im going to do it. Well as far as weight reduction, just the basic stuff, jack, spare, brackets, center console, gas tank, bumper. It weighed 3985 with the old nitrous setup but I figured it gained a little with the turbo stuff. Its gonna gain another 30 with the new turbo lol
Old 10-01-2012, 05:22 PM
o2camaross's Avatar
yea ill look into the housings. If I go to sell the on3 ill message you. thanks
Old 10-01-2012, 06:29 PM
Beanslsxnova's Avatar
i have an s475 with a t6 1.10 83mm wheel with about 12 passes on it for a 6.0 project im working on. buy that turbo and trade me! haha i need the 1.32 housing for what im trying to accomplish
Old 10-01-2012, 06:37 PM
o2camaross's Avatar
Thats a good idea!! Let me get it this weekend and Ill let you know!!
Old 10-01-2012, 06:52 PM
awesome let me know
Old 10-01-2012, 07:22 PM
BottleFedZ346's Avatar
Spool won't be as bad as you think, we have a 5.3/s480 240sx with the t6 1.32 backside and makes full boost around 3200-3500rpms....
Old 10-01-2012, 07:31 PM
831jd's Avatar
Whats his rwhp ^
Quick Reply: T6 s475 on 5.3 truck?
