any truth to this info...???
Old 10-02-2012, 09:43 AM
SprChrgdGT's Avatar
Default any truth to this info...???
I have a 99 ss m6.... I would like to do H/C/I.... as far as a head setup, if the following info is true, what are some opinions on getting a set of 243 heads and having them milled .030 to raise the compression? I plan on a h/c/i combo with a 150 shot. Thanks for any opinions fella's...
If I remember correctly the LS6 (243) stronger spings than the LS1 (241) -
Hands down the LS6 head flows better than the LS1 due to the runner volumes and the smaller combustion chambers!
LS6 heads are refined and improved LS1 heads, basically:
- Intake runner volume increased to 210cc vs. 200
- Exhaust runner volume increased to 75cc. vs 70
- Combustion chamber is smaller at 64.45 cc vs 66.67
- Compression ratio is higher at 10.5:1 vs. 10.1:1
- "D" shaped exhaust ports vs round
If you mill the deck on the LS6 head 0.030" you will get 11.1:1 compression.
Flow #'s (Stock heads @ 28") Head vs Lift
Head/.200/.300/.350/.400/.450/.500/.550/.600
LS1 / 137/ 187/ 207/ 223/ 228/ 237/ 242/ 243
LS6 / 156/ 204/ 225/ 243/ 257/ 268/ 275/ 278
In short smaller and more efficient combustion chamber allows quicker burn times, requires less ignition timing resulting in higher torque.
Old 10-02-2012, 09:49 AM
kinglt-1's Avatar
if you send the 243's out to a reputable company such as Advanced Inductions, they can make killer power. 450+ whp on the right combination of parts. In stock form, milled, and cleaned up 430whp should be about par with a decent cam in the 226-228 duration range.
Old 10-02-2012, 10:15 AM
SprChrgdGT's Avatar
nice... I believe the nitrous would love the extra compression too. That may be the route I take then.
Is the fast intake worth much more than the ls6 intake?
Old 10-02-2012, 10:59 AM
SSCamaro99_3's Avatar
The 243's had marginally better valve springs. However, just about any aftermarket cam upgrade will require new valve springs.
Old 10-02-2012, 01:48 PM
SprChrgdGT's Avatar
really liking this sound. Wish there was more info on this guys setup.
Old 10-02-2012, 02:07 PM
Grr
Grr's Avatar
you can mill the heads ALOT in an NA application and have good success, case in point my stock bottom end with 243 heads is right at 13:1. You would have no problems milling .030
Old 10-02-2012, 02:39 PM
PREDATOR-Z's Avatar
The problem lies in the size cam he will be able to run.
Old 10-02-2012, 02:53 PM
SprChrgdGT's Avatar
Yeah I was thinking that with the heads milled, you cant run as large of a cam. Is that right?
Old 10-02-2012, 03:09 PM
Grr
Grr's Avatar
not without doing the appropriate cutting of the pistons. If you do not wish to do so you are much more limited in cam selection when milling
Old 10-02-2012, 04:30 PM
PREDATOR-Z's Avatar
Correct. Another option is to send your stock heads to AI and get their 241 219cc CNC program. Then can keep stock valves, no milling and weld the chambers to reduce size and therefore you get close to stock clearance but with higher compression.
Old 10-04-2012, 01:18 AM
95ONE's Avatar
I'm curious how you got to 13:1 with your application!?
Stock bottom end 346?
What size chambers do you have? - cc's?
headgasket thickness?
How much did you mill your head?
If more than .060, did you run into any intake manifold fitment issues?
Old 10-04-2012, 02:22 AM
bww3588's Avatar
The most common reason for intake fitnemt issues is people not milling the intake face of the head like they are supposed to. Any amount milled off the deck surface should not cause intake fitnemt issues if the machine shop did the milling correctly.
Old 10-04-2012, 03:19 AM
PREDATOR-Z's Avatar
That is because Grr is not telling you the whole story.
Old 10-04-2012, 09:11 AM
Grr
Grr's Avatar
Sure guy, not telling the whole story. Whatever man
Stock 346, .05 stock mls gasket
Pistons are out .008
Heads are 46.x cc
best guess is they are milled around .135-.140, do not remember what was taken off the first time. Calculated at 12.96:1
Dynamic compression is 9.65:1
Old 10-04-2012, 10:03 AM
PREDATOR-Z's Avatar
Still not the full story....
Old 10-04-2012, 10:23 AM
Grr
Grr's Avatar
So tell me what the full story is since I obviously don't know what I did. 0
P to v bullshit?
Run a smaller cam then, this cam is a little overkill for most anyway
Old 10-04-2012, 10:27 AM
Drokkers's Avatar
Old 10-04-2012, 10:50 AM
The Scammer Hammer
dr_whigham's Avatar
You're 900ft above sea level..... but I still don't get how you can safely run 9.65:1 dynamic on 93
Old 10-04-2012, 10:53 AM
Sales@Tick's Avatar
He runs E85....
Old 10-04-2012, 11:47 AM
PREDATOR-Z's Avatar
Originally Posted by Martin@Tick
He runs E85....
bingo
Quick Reply: any truth to this info...???
