ABS and BRAKE lights on!! HELP!!!!
my abs inop light stays on but as soon as i move the car, the brake light comes on... jayson at mti said it was the plug on top of my rear end , i checked it and everything looked fine... and it is still on.. where else can i check and where do those wires run?? that light is just drivin me insane, both of them...
i just dont like drivin my car with the lights on....
check the wires that go to the sensors --i accidently cut one with a grinder once--also you might be able to clean the sensor--or it could just be a fuse
check the abs fuse
check the abs fuse
in my old LT1 camaro the ABS inop light came on because the brake light on the spoiler was out. Once I replaced the bulb everything was back to normal. Might want to check that.
I had the same problem once. It turned out that the ground stud was loose. It was the bolt on top of the drivers side fender that has a ground wire running to it. Check that to see if it's tight.
