Heads/CAM HELP !!!
Old 10-03-2012, 11:42 AM
kissmy99ss's Avatar
Default Heads/CAM HELP !!!
I would have asked in other related threads but didnt want to hi-jack someones thread lol.
I'm looking at getting a heads/cam package. my mod list is this (1999 Camaro SS M6)
Corsa Cat-back
Hooker long tubes
LCA's with reloc. brackets
Bilstein Shocks
Short shifter
Built 10 bolt with moser axels and moser 373's
LID
315 Nitto DR's
I'm a college guy and I drive my care daily, so i need it to stay street friendly however I want to make as much power as I can while still being able to have it as a DD. I have never dyno'ed my car so the power it makes right now I have no clue on. Can you guys shoot me some numbers on what you think my car puts down now? and how much i would be looking at with your suggested heads/cam setup? Also can a $3,000 budget get it done?
My best time at the 1/8 track is a 8.8 @84 with a 2.1 60ft that was without the relocation brackets,headers and bilsteins on.
Old 10-03-2012, 11:52 AM
reeperz28's Avatar
Bolt on ls1's with a 6 speed trans usually make in the area of 335- 350 rwhp. Torque is close to hp . A good mild setup for daily driving and budget friendly ish would be some prc 2.5 heads perferably 5.3 's imo. And the 224 cam or 228 from texas speed. With a stock intake it should be good for 420 rwhp average. Study the dyno section and search different heads cam packages.
Old 10-03-2012, 12:02 PM
kissmy99ss's Avatar
Thanks for your input, How often will I need to change out the springs with a 228 cam ?
Old 10-03-2012, 04:32 PM
kissmy99ss's Avatar
Anyone else have some input for me?
Old 10-03-2012, 08:00 PM
2000PewterT/A's Avatar
I check mine every 20k miles, if they are in spec I put them back in.
Old 10-03-2012, 09:52 PM
kissmy99ss's Avatar
well thats not too bad, I just dont want a setup where I have to change or check them every 5k cause that would be a lot of money considering i drive this thing daily lol
Old 10-04-2012, 11:21 PM
1loudTransAm's Avatar
I Daily Drive my car 10 miles a day. I got a 228R Cam fom Texas Speed, very good cam. with a 3600 Stall and a tune. I also getting 14mpg on the city & 22mpg on the highway. 220R, 224R, 228R Cam and PRC LS6 Stage 1 or 2.5 heads are good for DD
Old 10-06-2012, 12:12 AM
kissmy99ss's Avatar
How much out the door should a head/cam package run me including install?
Old 10-06-2012, 03:53 AM
arock24's Avatar
$3000-3500...possibly a little more depending on how much labor is in your area.
Old 10-06-2012, 09:41 AM
tjwashow's Avatar
600 for cam package from Texas speed includes spring pushrods and cam. Get some heads for 1500 and find a local guy to install for you. Preferably a member from the forum who knows what they are doing.
Old 10-06-2012, 09:54 AM
arock24's Avatar
Don't forget about the oil pump, trunion upgrade, lifters, trays, timing chain, and gaskets which will run you about another $650. If you're on a strict budget, pick up a stock set of 243's on here for $400 and get them freshened up at you local machine shop, all for under a grand. Do it right and go with dual springs from TSP, the kit is $740 which isn't bad. This will put you right at $2100 for parts, not including installation or tune. Like I said, $3500 is a little closer to reality for a decent H/C setup after it's all said and done if you have to pay for labor.
Old 10-06-2012, 12:00 PM
kissmy99ss's Avatar
sounds reasonable. For that price is it possible to just pick up a used d1sc kit and throw it on and gain the same amount of HP ?
Old 10-06-2012, 03:04 PM
99 Black Bird T/A's Avatar
Received 1,432 Likes on 992 Posts
Might change the coolant when you drain it for H & C and flush the radiator if that hasn't been done in a while. It's easy to do a little preventive maintaince while doing H&C. Don't be surprised if a radiator hose or two needs replacing etc. Mine is also a 99 about due for new radiator hoses. I would allow some extra money for things that come up unexpected at least a buffer of $1000.
Does your clutch hold well? Sometimes with a big power upgrade a new clutch isn't too far away. I was lucky my stock clutch held up fine after H&C and is still in the car and doesn't slip.
If your doing a 224 or 228 @.050 cam, I suggest allowing some extra money for tuning. This will make for a much better daily driver experience.
Likewise, if you don't have an LS6 intake, I'd get one for the H&C swap so you can get the most out of the mod's your making.
My H & C set up while very old over ten years so I'm not up on the current prices for H & C. I have a 224 XE-R cam. Typically my springs have needed replacement at about 30,000 miles but I'm pretty easy on the car. If I beat on the car a lot, I would be looking at the springs after 20,000 miles.
Old 10-06-2012, 03:28 PM
MikeWS6's Avatar
TSP 228R is a great cam. 50hp gains with no low end loss and its pretty streetable for mostly everyone.
Old 10-06-2012, 03:59 PM
kissmy99ss's Avatar
I have a new radiator and ALL new hoses less than 10K miles so im good there. My clutch and intake I have plans for already replacing them before the heads cam swap. Only thing I think I'll have to be careful with is my rearend. I have a 10 bolt as beefed up as it can get, but lets face it, it's still just a 10-bolt lol
Old 10-06-2012, 04:17 PM
KingPin1094's Avatar
im gonna do the same thing but im going a little more radical. im gonna do the EPS 236/248 cam with .617/.617 lift with PRC 225cc heads and a FAST 92/92 setup with upgraded injectors and the full bolt ons. Im looking to make 450whp+ and still have it be a DD. And im also hoping (and this is really hopeful with a good tune and a light foot) to get 18-25 mpg. i know this really doesnt pertain to you but i figured id through my 2 cents in.
Old 10-07-2012, 12:02 AM
kissmy99ss's Avatar
Hopefully you have a good rear-end, cause with that setup your gonna need one. If you drive it softly no you wont, but as soon as you get that thing on a track and if you get it to hook said goodbye to that 10 bolt. lol not to mention your clutch will need upgrading, if you havn't done that already...
Quick Reply: Heads/CAM HELP !!!
