where to connect my second pump
Old 10-03-2012, 12:36 PM
cr2
cr2's Avatar
Default where to connect my second pump
have two pumps in the tank. ones connected to the factory harness the other was run off a holb switch. holb switch went bad almost causing huge problems while tunning. i want to run both pumps at all times now. i have a return system -8 line fuel system. where can i wire the second pump so that it comes on with key ignition???
Old 10-03-2012, 01:31 PM
Boosted Firehawk's Avatar
Run it str8 to the battery with a relay and have it come on only when the car turns on.
Old 10-03-2012, 04:30 PM
cr2
cr2's Avatar
from the relay what should i hook the 12v refrance wire too? something that only comes on when i turn the key on??o
Old 10-03-2012, 08:04 PM
cr2
cr2's Avatar
does it have to be from pcm and if so does anyone know witch wire it is from the pcm.
Old 10-04-2012, 02:20 PM
jtotheizzo's Avatar
depends on where you want to mount the relay. If you mount it in the back grab the reference from the same wire that turns on the other pump. If you want to put the relay in the engine compartment then grab the reference at the fuel pump relay. and if you are looking for wire colors you might have to provide vehicle information FYI.
Quick Reply: where to connect my second pump
