step closer to H/C build being put together..
some of you may remember my other post. had some different stock heads. went ahead and sold those...
so new set up. i have some 799 heads on their way tomorrow morning. i also have the thunder racing TRak cam. the heads are just bair with valves. i will be getting some PRC 675" spring kit to help cover that..
HERE ARE MY QUESTIONS..
what size push rods?
what size/kind gasket?
should i mill the heads? previous owner suggested .005 mill to clear up some surface scratches. (he did some smoothing on ports with porting tool) suggest it is possible to have 10cfm over stock.
oil pump, and all that other stuff i know what to get. im going to also get ls6 pcv conversion and ls6 coolant pipe thing thats needed.
i was also planning a ls6 intake
i have the TR TRak cam. 232/235 595' 644' 112lsa
thank you for all help. this is my first personal heads and cam build. want to put together a nice little package that can potentially hit 440rwhp....
I dont want to need to fly cut. I wouldn't mind bumping compression if possible. I would like a f.a.s.t but thats alot more expensive than getting an ls2 intake that has a 90mm openimg.
i was also planning a ls2 intake.. any objections?
As far as the LS2 intake, make sure it's ported or you get it ported. What TB will you be running with it? It does have the 4 bolt pattern...should have posted this sooner, I just sold a ported LS2 intake this week.
Someone could correct me if I'm wrong, but shouldn't you just measure for PR length instead of taking a guess? That was my conclusion while doing research for my build.
i guess i should give thunder racing a call. that does sound like best bet for getting all correct messurements. im sure there has been many in my position. i just want to buy everything so that i can start on a friday and end on a sunday night. i dont want to need to take apart measure and wait. i know that is the best and correct way but im not so patient nor will work alow it. i need to do it all at once. when i had my 2000 ss i didnt measure. i just bought the ms3 and stock style hardened pushrods with stock heads.. however now that im doing another build different car. i do not know all the differences between stock casting ls1 heads and 243/799 casting heads. i just know they flow better.
There's a bunch of 4 bolt TB out there, I just wanted to make sure you were aware it was a different pattern. You can even find those pretty easy on the classifieds here...As far as porting the LS2 I don't know how it will match up with 799s but one of the things I was reading was how they're assemble and have kind of a rougher finish than usual so it needs to be ported for that extra potential.
As far as the PR, you could just throw some in there, but those are easy to switch out even once everything is done. I'm just the type that has learned to do things the right way to save headaches in the future. Who knows, you may end up lucky with needing the 7.4s but at least you checked.
any help on what headgasket to go with? should i try and bump compression with this cam or just leave it stock? And does upgrading from new stock valves have any benifit?
Bump for any hints tips or insights...
I still need to get correct pushrods im thinking stock size should be fine.
Would i benifit from upgrading.my already.new.stock.valves?
Would i benift from a mill on the.heads, and not need to fly cut.?
What size n type of head gasket? Stock or mls?
I wouldn't just guess what pushrod size you need order a pushrod checker for 10-20$ and make sure u don't have to do it twice. Nothing really to benefit to upgrade to newer valves unless you get bigger ones and have a port job to match for them id stay stock unless u want new valves for some reason. U could mill your heads for more compression but That could affect your PTV depending what size cam your running then you would have to measure, but if you just clean them up you should be alright.. Stock size gaskets should work the mls gaskets. Also just my opinion I'd go with a ls6 mani suitcase you can reuse your stock TB port it even and I think I read it outflows the ls2 manifold. U can get your ls6 retrofitted to fit a 90mm TB as well, just do a quick search bud
ill agree with measuring pushrods. nothing funner than putting in pushrods someone reccomends...then pulling them back out and taking a hit on selling them...then waiting to get new ones the right length...
head gasket really depends on how much CR you want. talk to thunder racing...i would think stock thickness would be fine...itll still bump your compression up with the 799s..
ive tried multiple times to get ahold of thunder racing with no luck neither through email, voice mail or direct phone.
so far i am thinking stock thickness mls gaskets since you mentioned 799s will bump my compression and either measure length of push rods or unless i find someone with same cam and heads. would it be the same push rod length with stock ls1 heads and my 799 heads?
I'm sorry I missed that part. There were a few times it took several days to get a hold of them.
After talking to Shane I understand why its so hard to get a hold of someone because he spends so much time with a customer. I was frustrated a few times too but there was no rush on my build so it wasn't a big deal.
It's late and I will throw a few things out there. If its been already stated before I apologize.
Push rods should be the very last thing you do. Varying factors like the cam's base circle, deck height, head gasket thickness, how much the heads have been milled, all play into push rod length. Guessing it just a bad idea when you start changing so many parts. If it was a bone stock engine running a 224 cam it would be a different story.
Things like; how much you should have the heads milled/resurfaced, how much compression, which head gaskets will greatly depend on your current PTV clearance.
After you know that number you will know how much you can/can't take off the cylinder head and what gasket you can run.
For head gaskets you want to have the best quench you can. Around .040 is suppose to be optimal. With a tighter quench you can run more compression because the burn is better controlled and it won't be prone to detonation. Anything tighter than that is risky. Yeah you will see some people say they run it closer but IMO its not worth it. A lot of people, including myself, run the stock GM MLS gasket which is .051. They are cheap and they seal good. To get to a .040-.045 you are needing Cometic's which are way more expensive than the stock stuff.
Hope this helps a little. It's late and I need to be up in the morning to go work on stuff.
J
J
