What is infront of my crank timing gear?
It looks like some type of wheel for the crank position sensor. How do I get it off. Is it safe to just pull it with a 3 jaw puller. I need to remove it to change my timing set.
The reluctor for the CPS should just slide off. I would not put a puller on it. It might bend. Perhaps you could just pull the crank gear and the reluctor (if stuck) should slide off with it.
Going back with a standard cloyes timing set. As soon as I get all the goodies in I'm gonna put the setup in my signature. It's on the to do list. Lol
Thanks
Thanks
