Just got my Strano Spings......
Old 10-04-2012, 09:49 PM
GMC5.3's Avatar
Default Just got my Strano Spings......
Pumped to get these babys on the SOM, happening in 2 days, any tips or tricks so i dont kill myself????? Im following L1 How to write up...
Pics to follow
Old 10-04-2012, 10:08 PM
WhiteKnight '01's Avatar
POST BEFORE AND AFTER PICTURES! How much are you lowering it?
Old 10-04-2012, 10:15 PM
02TransAm/Batmobile's Avatar
Old 10-04-2012, 10:32 PM
GMC5.3's Avatar
1.2 inchs, kinda nervous now, did some research and saw that some people have had trouble with rusted nuts and such specifically the rubber boot and sway bar links
How many of you have ran into this problem and broke something?
Old 10-05-2012, 12:12 AM
TruBloodTransAm's Avatar
Just get some WD-40 or PB Blaster and let it soak in real well. Shouldn't be a problem.
Old 10-05-2012, 12:31 AM
TA_Freak's Avatar
Just get those shock springs compressed and saw the shaft with a saws all if the mount nut is fused to the shaft. Took me a few seconds to get through it. It was the easiest part of the job for me. If the end link bolt(s) break then you probably needed to change them anyways. You can get those at the local parts houses.
Old 10-05-2012, 09:06 AM
GMC5.3's Avatar
You wouldn't happen to know what size would you , I'm going too be doing this in a pretty small town that has few parts stores,
Old 10-05-2012, 01:48 PM
sscamaroburn02's Avatar
Just be careful with the endlinks. Soak them real good and turn them slowly and you should be just fine. Go slow and don't forgot anything when you are re-installing back on the car.
Old 10-06-2012, 11:57 PM
GMC5.3's Avatar
Finished after a 10 hr day installing these for the first time, best thing is I'm still alive and I have all my fingers, pics to follow in the morning, do strano springs still need time to settle also?
Old 10-07-2012, 08:42 AM
ramairetransam's Avatar
good to hear you got it done , in for pics .
Old 10-07-2012, 08:45 AM
HioSSilver's Avatar
I've had my Koni's and Strano springs for months. I'm goin out to the shop now to change to them from my Bilsteins and hotchkis springs than has been on the car forever.
Old 10-07-2012, 08:51 AM
lsmaxxed's Avatar
I busted my sway bar links there only 10 bux at auto zone though just make sure you use both spring compressors on each spring
Old 10-07-2012, 08:46 PM
GMC5.3's Avatar
Before #1
Before #2
Afters will be posted tomorrow after the wash
Old 10-08-2012, 07:20 AM
any better before pics of the front end?
Old 10-09-2012, 11:06 AM
GMC5.3's Avatar
Before i painted the rims bronze
Without lowering springs
With Stranos, stock shocks
Old 10-09-2012, 11:16 AM
SparkyJJO's Avatar
Whoa, that must have ridden horribly.
Old 10-09-2012, 11:33 AM
GMC5.3's Avatar
its a little more bumpy yes lol
Old 10-09-2012, 12:09 PM
metalmilitia606's Avatar
I honestly would have waited until you bought shocks. Those springs are going to wear your stockers really fast and you'll have to do all that work over again.
Old 10-09-2012, 12:33 PM
SparkyJJO's Avatar
Stock DeCrapons are worn from the factory
Old 10-09-2012, 12:52 PM
Fosnot's Avatar
I don't always use stock shocks, but when I do, I think "Koni"
Quick Reply: Just got my Strano Spings......
