Who is running shaft mounted rocker arms? LS7 Jesel vs. Crane vs. T&D vs. Crower
I don't spend much time here, mostly visit the Corvette forums, but figured you guys would have larger knowlege base of shaft mounted rockers on LS based engines.
So, who is running any of the following shaft mounted rockers? I'm looking into a set to run with a LPE GT9 camshaft on an LS7.
I'm trying to get some first hand experience of each brand, and the pros/cons of each.
Crower 74107F 1.55 ratio, MSRP = $1360
Jesel KPS-2065416T 1.55 ratio, MSRP = $2247
Comp Cans 1523 1.80 ratio, MSRP = $1545
T&D 2008 1.60 ratio, MSRP = $1220
I'm leaning towards the Comp Cams because of the higher lift ratio, and the price.
But would like to hear from others.
I have a set of LSX-LS7 heads which are going to LPE for porting, and will be machined for shaft mounted rockers while there.
LS1TECH Sponsor
T & D for the money, they build nice stuff. Give them a call, I think they will build them to any ratio.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
most of those specs are not ratios you have listed ls7 needs the stock 1.8 to work proper
i have lsx ls7 heads that have been fit for the crower shaft rocker they are SS a bit heavier but way stronger than a aluminum rocker
street = stay away from aluminum rockers
strip only alum is great
The crower product has always been bullet proof from my experience. Aluminum is questionable in this area over a long period or extended duty cycle. I've owned a crower set for 15 years and have been super happy with them.
The roller tip is exclusive last time I checked and supposedly lowers oil temps up to 50 degrees at the tip. With the friction generated in that area, it's quite possible.
I've used the Jesel LS7 shafts on multiple builds. They are 1.8 ratio, don't have part number handy. I have only run these on big$$, big HP motors built for 75/25 or so track/street use. Never ran into any durability issues and wouldn't expect to with a proven rocker design from them. As stated the factory rocker pedestals will need to be machined off/ heads machined and you may need to modify valve covers depending on what VC's you're running.
I was messing around today on an LS with the Jesel setup. Very nice package. They were the Mohawk2 bodies and J2K style shafts. They were using the Crane Cams billet valve covers on them and the covers fit out of the box with no modification.
Did you have Crower make a custon rocker? I really like them, but the specs I see are for a 1.55 ratio, not a 1.8. I also have the LSX-LS7 heads, and am going to run them with the LPE GT9 camshaft.
Thanks. I will call them, and see what they say. They look like a nice piece as well, and if I can get them in a 1.8 ratio I may go for them.
thats not the ratio 1.55 its the pivot point
all ls motors stock and aftermarket will be 1.7 - 1.8 ratio anything else is custom and would not be listed
