Can the rear end slip ?
Old 10-06-2012, 02:39 PM
NitrOmm's Avatar
Default Can the rear end slip ?
I've noticed something slipping I can't believe it's the clutch as its fairly new.
I'm thinking maybe rear end ?
It happened once when cold on flat ground. however, it happens often when I am gong up hill. Say third gear and a heavy blip of the throttle, I feel It slip for a few seconds then catch. .??? Possible.
Specs in sig
Old 10-06-2012, 03:27 PM
Dirty Dog's Avatar
How could a toothed gear slip?
Old 10-06-2012, 03:32 PM
lsmaxxed's Avatar
Its your clutch
Old 10-06-2012, 03:51 PM
Carter01's Avatar
Clutch. In 3rd going up a hill the car is under significant load. Most of the time a clutch won't slip under hard acceleration from a dead stop because the load is very minimal.
Old 10-06-2012, 03:56 PM
lsmaxxed's Avatar
Check your trans mount then
Old 10-06-2012, 06:19 PM
NitrOmm's Avatar
Just wishful thinking. I'm already looking at the new monster twin.
Old 10-07-2012, 12:46 AM
BoxeDK's Avatar
Do you have enough fluid in your transmission?
check with engine warm, in P, and while engine is running.
Posted from LS1Tech.com App for Android
Old 10-07-2012, 02:00 AM
Dirty Dog's Avatar
Since he mentioned that his CLUTCH was 'fairly new' I don't think this is possible...
Old 10-07-2012, 11:07 AM
jimmyducati's Avatar
possible that you just lost traction for a moment?
Quick Reply: Can the rear end slip ?
