93 Reef Blue LSX Notchback Build
Old 10-06-2012, 07:58 PM
snipes's Avatar
Default 93 Reef Blue LSX Notchback Build
My 91 Coupe project is just about done so I am looking to get the next project underway:banana:
The new project is a 1993 Reef Blue Coupe, originally a 4 banger car that was recently painted, caged and some thru the floor sub frame connectors tied in.
The day I picked her up:
1st order of business when she arrived home was tossing the 4 banger wheels in favor of some pony wheels and adding some clear head lights:beerchug:
and parked next to her new sister:pop:
Been stock piling parts for a good while now and hope to make some headway with her this winter.
Old 10-06-2012, 08:10 PM
fknsmshn's Avatar
A nice looking couple there
Old 10-06-2012, 08:39 PM
Tig
Tig's Avatar
Nice starting point.
Not to get off topic but, hows about a quick looksy at her sister
Old 10-06-2012, 09:19 PM
Tweek's Avatar
I was about to ask the same thing. Whats the specs on the wheels and tires on the maroon one???
Old 10-07-2012, 06:58 AM
snipes's Avatar
thanks guys...i look forward to the new build with the ls power plant
i have a long write up on the dark cherry pearl car here if you guys are interested:
http://hpmustangs.com/forum/forumdisplay.php?f=119
Old 10-07-2012, 07:04 AM
snipes's Avatar
Wheels on the sister car are 18x9 and 18x10. 255 and 275/35's.
Old 10-07-2012, 07:06 AM
jaywill's Avatar
Nice !
Old 10-07-2012, 08:23 AM
Tig
Tig's Avatar
After going through her sisters build thread, I think we are all looking forward to this LS build
Very nice. Wow, a ton of work went into that bad boy. Great job.
Love those wheels on the Coupe, really sets it off.
Thanks for sharing.
Old 10-07-2012, 09:20 AM
snipes's Avatar
Thanks man.... The 91 snowballed into a project that seemingly would never end Im gonna try an keep this build a bit simpler.
Old 10-09-2012, 02:37 PM
snipes's Avatar
Over the weekend I power washed the interior in preparation for some Dyna pro coating.
Before:
After:
Old 10-09-2012, 02:40 PM
snipes's Avatar
Scored an awesome deal on a set of wheels last night:banana:
On the look out for a decent set of 245/45/17 front tires and 275 DR's if anyone comes across any.
Old 10-09-2012, 06:29 PM
Rybar's Avatar
Cool build, what are the plans. Your other stang looks killer too.
Old 10-10-2012, 11:47 AM
snipes's Avatar
For now, im gonna keep it simple and make the car user friendly and see what kind of track times it will run. Once I get comfortable with it, I have no qualms about doing some heads or head work, cam and def a 125 shot.
Old 10-10-2012, 07:38 PM
Bowtiedford's Avatar
looks great, good luck
Old 08-27-2013, 07:04 AM
snipes's Avatar
Been slowly stock piling more parts.
- Tubular A Arms
- Front Coil overs
- Polished CC plates
- QA1 Adj struts
- 275/40/17 Rear tires
- 89 non air bag adj steering column
- Cross drilled/slotted front and rear rotors
- PBR Dual piston front calipers
- 99+ rear GT calipers
- 93 Cobra Booster and master cylinder
- Fox length 5 lug axles
- braided fuel line and misc fittings
- PSI Stand alone LS1 harness and 99+ ECM
- 351 long tube headers with LS1 Flanges to be welded on
- 4L60 Deep sump trans pan
- Mac cat back
snipes's Avatar
AJE conversion K member, LS Motor mounts, GM to Fox Cross Member and spring perches:rockon:
Old 08-27-2013, 07:05 AM
snipes's Avatar
Old 08-27-2013, 07:06 AM
snipes's Avatar
Diet time:
Old 08-27-2013, 07:07 AM
snipes's Avatar
swapped the axles out for fox length 5 lug units.
Mounted and centered the AJE K member.
94 Spindles, coil overs, adj struts and cc plates are in.
Old 08-27-2013, 07:08 AM
snipes's Avatar
Back on all 4's
Quick Reply: 93 Reef Blue LSX Notchback Build
