01 5.3 wiring harness ?
Old 10-07-2012, 05:36 PM
94heritage's Avatar
Default 01 5.3 wiring harness ?
Going to pick up a 5.3 the motors already pulled and the guy said if i want the pcm and wiring i have to pull it my self how much of the truck harness do i need to make the 5.3 run?
Old 10-07-2012, 07:07 PM
T76s10's Avatar
Iac, tps, iat, alt, cmp, cps, map, fuel injectors
Old 10-07-2012, 07:12 PM
94heritage's Avatar
i appreciate the quick reply i am putting this engine in an 84 elcamino and just wasnt sure if i needed the whole wiring harness from the truck or if jst the enigne side is needed
Old 10-08-2012, 03:27 PM
T76s10's Avatar
yep just the engine. if your using a 4l60e or 4l80e be sure to get the harness for the tranny too. on the harness i pulled from a junkyard they had the tranny harness snipped off but i run a th400 so i didnt need it.
Old 10-08-2012, 03:29 PM
T76s10's Avatar
btw, lt1swap.com is by far the best website to go about doing your own harness work. every bit of info you need for re wiring your harness is on there.
Old 10-08-2012, 05:16 PM
94heritage's Avatar
thanks for all the help man
Old 10-09-2012, 12:58 PM
omc8's Avatar
Is a Gen IV harness anymore difficult to repin and clean up than a Gen III truck harness ?
Old 10-09-2012, 03:36 PM
T76s10's Avatar
no. the gen IV harness (2005-2007) is the exact same as the gen III harness's from 03' and 04'. in 99-02 i think the alternator wires were a little different but im not totally sure you would have to differ between pinouts. in 2008-present the pinouts might have changed but im not totally sure because lt1swap.com doesnt have the pinouts for those engines yet. if you have a gen IV harness and want drive by cable, get a 99-02 ecm. that way the ecm's are compatable with dbc. in 03'+ some ecm's are drive by wire ONLY. that means that you cant use a dbc throttle body. heres the truck pinouts for future reference
99-02 pinouts
03-07 pinouts
Old 10-09-2012, 03:40 PM
T76s10's Avatar
btw, i used a harness from an 04' silverado on a 2000 ecm. i cut two tabs off of the green ecm connector to fit into the 2000 ecm where the red ecm connector would go. i used the 99-02 pinouts and it all worked great. and i removed all the pins that i didnt need to clean up my harness.
Old 10-09-2012, 04:31 PM
omc8's Avatar
Originally Posted by T76s10
no. the gen IV harness (2005-2007) is the exact same as the gen III harness's from 03' and 04'. in 99-02 i think the alternator wires were a little different but I'm not totally sure you would have to differ between pinouts. in 2008-present the pinouts might have changed but I'm not totally sure because lt1swap.com doesnt have the pinouts for those engines yet. if you have a gen IV harness and want drive by cable, get a 99-02 ecm. that way the ecm's are compatable with dbc. in 03'+ some ecm's are drive by wire ONLY. that means that you cant use a dbc throttle body. heres the truck pinouts for future reference
99-02 pinouts
03-07 pinouts
If I go Gen IV it will be 08 and keep it dbw , I dont think there are pinouts for the new body style at lt1swap.com yet. How difficult would it be to keep the following functions oil pressure, alt gauge, and coolant temp ? The vehicle its going in is a 99 Amigo with manual trans.
Old 10-09-2012, 05:01 PM
T76s10's Avatar
i dont run the oil pressure sender because the computer doesnt need to see it and i dont run an alt guage. i just run a voltmeter and mechanical oil pressure guage (you could do electrical if you wanted). the only thing the ecm needs to see is ect (coolant temp) along with the other stuff i posted for 94heritage. since you dont need to re pin your harness because your using a matching ecm i would just cut out all the connectors you dont need (tranny, evap, egr, etc.) and then go ahead and connect the rest of your pigtails to your engine
Old 10-10-2012, 11:39 AM
omc8's Avatar
I have not decided if Im going Gen IV yet or not. But thanks for the quick response back. This helped , if I decide to go electric on guages whats the chance I can connect to the Amigo dash ? It may be best to mechanical !
Old 10-10-2012, 12:45 PM
LS1Tech Sponsor
psiconversion's Avatar
If you are going with a 58x Gen IV (mid 2007 and up) then the wiring and controller are completely different from the Gen III stuff. If you are going to go Drive by Wire on the 24x Gen III stuff, make sure you get the TAC module and Pedal as that will keep the cost lower. If you are using a 58x, then you only need the pedal, there is no tac module. If you are planning on drive by cable, forgo the Gen IV and stick with a Gen III as the Gen IV controllers will not operate drive by cable. Hope that helps.
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Old 10-10-2012, 05:09 PM
T76s10's Avatar
im not sure about the amigo dash but its cheaper and easier to go mechanical. thats what i did and works out great
omc8's Avatar
If I go Gen IV it will be 08 and I will get the harness ,ecm, dbw TAC and pedal all from the donor truck. I'm not sure if the pedal from the the truck will work in my Amigo tho. I talked with a guy in my area that tried to use a truck pedal in his 69 Chevelle and he said it would not work ,he went with one out of a vette about the year as his Tac and TB.
Old 10-10-2012, 05:24 PM
T76s10's Avatar
why wouldnt the pedal work? if your handy enough, you'd think you could make some sort of bracket to rig something up.
Old 10-10-2012, 05:38 PM
aknovaman's Avatar
NOTE: edited based upon further research.
One issue with the pedals is gm changed the wire order and if you don't have the correct order, it will set codes and not allow the engine to accelerate, no matter how you wire it. You can NOT use any pedal with ls1 style, e40 and e38 pcm's. The tacc must match the PCM, operating system, and file settings. The pedal simply consists of two TPS in one package.
E38, E40 and LS1 style pedals have different resistances that produce different voltages at closed and full throttle. So even if you wire them up for the correct high, wiper and ground, it still wont function and will set codes.
Old 10-10-2012, 06:29 PM
T76s10's Avatar
Sounds like you know your dbw lol
Old 10-11-2012, 08:54 AM
omc8's Avatar
The problem he had was one that was too big , I think he did cut it down . But the biggest problem was throttle response was too responsive , it would ramp up to quickly. If you barely touch the pedal and it would launch forward.
Old 10-11-2012, 09:34 AM
1976CamaroGuy's Avatar
I have a 2004 5.3 in my Camaro I am still setting up, I found the stock silverado DBW pedal to be bulky and even after trimming it up and putting a stock Camaro pedal on it. I couldn't get the angle right. The body of the pedal was making it hard to place the pedal in a good spot.
And 2004 was a weird year and there aren't any alternatives to swapping out the pedal with one from a car or aftermarket....if you get one from a 2006 or later (I think, whatever year eliminated the tac module) you have better choices in pedals.
I ended up getting a DBC PCM from a 2004 GTO/Express Van and having it reprogrammed for my application, added the necessary wiring and throttle body.
And now I can use my stock 2nd gen pedal with a cable driven harness and it will look stock.
Quick Reply: 01 5.3 wiring harness ?
