Need some drag suspension advice please.
Old 10-08-2012, 01:25 PM
streetknight2's Avatar
Default Need some drag suspension advice please.
My car is a 02' Camaro. It has stock springs and shocks all the way around. Spohn Tunnel mount torque arm, adjustable lowers, LCA relocation brackets, Pro anti roll bar.
The car has -2 degrees pinion angle and LCA's are in center hole of brackets.
I run on 275/40r17 MT Drag radials. Car usually 60's in the mid to low 1.70's on motor. I have a 3200 stall in it.
I put a 100 shot on it and it does fine if I grab the button 40-50 feet out, but If I gas it out of the hole it blows the tires off and felt like some wheel hop.
What should I do? Shocks? 15" tires?
Thought about moving LCA's to bottom hole on LCA brackets.
The nitrous picked the car up 6/10 in the 1/8 hitting it 40-50 ft out, but still 60' about the same as on motor. I'd love to be able to make it stick, I think it's got another 2/10 in it in the 60' if I can get it to.
TIA
Old 10-10-2012, 11:53 AM
LS1Tech Premium Sponsor
ssvert99's Avatar
A good set of shocks like Strange or Afco will definitely help your cause, and a bit of adjustments from there. The 17" wheels aren't helping the situation, but we can work with it. Give me a call!
Quick Reply: Need some drag suspension advice please.
