will these springs work?
LS1Tech Sponsor
Received 1,119 Likes
LS1Tech Sponsor
They’re 2 reasons we sent you the link for the 26926 springs. The first reason is we are not able to find the ramp rate of the lobes for your cam and the suggested springs will withstand aggressive lobe designs. Secondly, our recommendation is based off the Comp catalog, which displays all cams that are over .600 comp use the 26926 spring. This could be due to longevity of the spring with that amount of lift. You are correct that Comp advertises 26925 with a .650″ maximum lift, but they do not recommend that number for their high lift cams.
