Coolant leaking from back of engine (passenger side)
Coolant is leaking from the back of the engine (at the firewall) passenger side. I googled it and read that there are freeze plugs. Is it coming from there? And how do I fix it?
I would get it on a rack and get a good look at the frost plugs to be sure that's what is leaking. While you're under there have a good look at the water pump and make sure coolant isn't leaking from the pump and and traveling down the front of the block to the block/oil pan mating area and running to the back of the engine. Another area to check, though I haven't seen one do it yet, is the coolant crossover pipe/plug on the rear passenger head.
Thanks alot! The car is now sucking air from that leak and overheating. No its not the pump, I put my hand behind the engine top side and could feel coolant. There is no space to really look behind the engine.
I was going to the city and at the checkpoint the officer heard my engine and stopped me. He then pressed the pedal and checked if its modifed engine or not. Then he checked rims. Then he let me go. I don't have any mods, just stock. I am outside usa. In usa do they fine you for any mods?
We have to pass emissions in most places every year or two and safety inspection to make sure the vehicel is road worthy, but nothing like what you have. Here you can get pulled over and get a small fine/repair order if your exhaust is too loud, visually unsafe, extremely low or jacked up but most of the time cops don't bother us unless we are doing something stupid to get pulled over in the first place.
I've blown strait through our emissions test here with strait pipe, longtube headers, no o2 sensors and no cats on my big cam stroker lol
Today I noticed the leak has minimized. before it was a small stream coming out (rear crossover gasket) but now small drips of water. I have put distilled water in my car, as I am in middle east. The water has gotten dirty. Shoould I put coolant, will it stop the leak? Or should I put "STOP LEAK". Even better, change the rear crossover gasket? Do I have to remove the head to change that or just top cover? If just the top cover I will change the gasket. Also we do not get concentrate of dexcool here, just predilluted available. The problem is when I drain the car, only half water comes out and half is in the system. Will it be ok if I put half predilluted dexcool and half water (already in car). I just want anti-rust, no anti freeze. Thanks for your time.
