Found GM Part Numbers for rear spring Insulators
Hope this is useful to others.........
I needed to replace the rear lower spring isolators since they were worn to just about nothing. I also replaced the passenger side upper isolator since it had a split.
After ALOT of chasing around I finally found them and here they are for EASY future reference for those who want to use the OEM replacements. According to the dealers I called, they don't even show a lower one even used on the F-body's...Nobody could explain why.
Rear Lower Isolator: 10247105
Rear Upper Isolator: 10290379
Old ones that came off my car...
Obviously I cant say all have them, but mine certainly did. Dealers, napa, Autozone etc & etc couldn't find the pn for that lower. I was able to id only partial pn's on each one that came out and actually had to guess on a digit. Sure enough, with the patience of a local dealer, we found it. Total pita this was
