E85 timing with boost on Gen III's?
Old 10-10-2012, 02:21 PM
CameronVic's Avatar
Default E85 timing with boost on Gen III's?
I just finished my build, and am learning about my MS3X and tuner studio. I don't have the EBC doing anything yet, my EMUSA 46mm is doing all the work! (7psi baby) I'm getting used to this before crank the boost up. I've got it at 18* right now with 7psi.
Setup:
5.3
241 heads (stock 5.3 heads had a bunch of studs sheered off and I didn't wanna waste time hitting water jackets) so it's roughly 9:1
hand me down cam (212 224 .550, with a 112 lsa *I think*), I know it made decent power on a pump gas 6.0
TH400 with a PTC converter.
95lb injectors, and a magnafuel 625
MP 76mm Q trim (I know, it's choking!)
3" thick, 24" X 10" intercooler.
I don't have the knock module with my MS3X, so I'm just gonna try to listen for the knocking over my open downpipe, and trunk mounted magnafuel 625.
Just curious as to what some of the timing is you guys are running with similar setups on E85. I've got about $1000 in the longblock, so I'm not scared to turn it up.
I'm thinking about 24* at 5psi, 22* at 10, and 20* @ 15.
Old 10-10-2012, 02:26 PM
pwrtrip75's Avatar
Setup:
5.3
If I only knew what a MSX3, a EBC, and a EMUSA was maybe I could help....lol.
Other than that.... what you have the timing set at is really close to mine.
Old 10-10-2012, 02:30 PM
JAX04's Avatar
MS3X is megasquirt, ECM
EBC- Im assuming is Electronic Boost Controller
and EMUSA is a brand of turbo stuff, like on3
Old 10-10-2012, 03:05 PM
lavoy's Avatar
15 degrees on e85 at 20 psi is very conservative. im running 15 at peak tq with pump and meth at 20 psi and it is stable as can be, e85 can handle timing like 110 race gas can.
Old 10-10-2012, 04:16 PM
CameronVic's Avatar
LMFAO, sorry I was so vague my friend! Now when you say really close, do you mean yours is more on the aggressive side? or Romney side?
Thanks for clearing that up for him! LOL. Now what timing you running?!?!
So you're saying I should add a degree or two to my figures?!
Old 10-10-2012, 05:45 PM
Ryans99ls1's Avatar
Im at 19* on ~10psi on a stock shortblock. with yours being a 5.3, i wouldnt be afraid to add a lil more.
Old 10-10-2012, 06:12 PM
Moderator
denmah's Avatar
he wrote 20deg at 15psi
Old 10-10-2012, 07:36 PM
lavoy's Avatar
haha dyslexia wins again
Old 10-10-2012, 08:40 PM
AutomagicLS1's Avatar
i've ran 24* before but wouldn't go much over that. nipped a piston on 26*
Old 10-10-2012, 10:01 PM
I8UR4RD's Avatar
lol me too
Old 10-10-2012, 10:05 PM
CameronVic's Avatar
At what boost? compression ratio? any other helpful details!? I'm trying to beat all the freakin B series honda guys! They're #@$%@#$% handing me my ***!
Old 10-11-2012, 07:16 AM
LS1NOVA's Avatar
18* at 23lbs.
Old 10-11-2012, 07:25 AM
LS1Tech Sponsor
hellbents10's Avatar
If fueling is good I would run up to 24* at 10psi if the car picks up mph or hp on the way. At 20psi you should be in the high teens, unless you have a really good intercooler.
Old 10-11-2012, 08:36 AM
rotary1307cc's Avatar
Id be watching plugs more than going by what others just say
E50 with one small nozzle of water/meth i picked up 2mph in the 8th going from 19-20* up to 22-23* timing
15psi boost, 10:1 motor. 7 range plugs, and looked just fine
Old 10-11-2012, 08:48 AM
22lbs, 26*, 9:2:1 using a B10EFS plug
This was also when I never had rear steam ports hooked up on the back of the heads and cracked a cylinder so I think it contributed to nipping a piston. When I say nipped it you could just see where it barely started to melt the piston area was smaller than a pencil eraser. I am using Wiseco pistons so I'm sure if it was stock pistons it would have been good night on that timing. I switched turbo's to make power alot easier without timing now. I think the most i'd ever run now is 20. no need to run anymore
Old 10-11-2012, 10:32 AM
pwrtrip75's Avatar
It ramps in just like yours and mine ended up at 14.5 degrees on my log at 20psi. Yes it is conservative.... a nice friendly street tune.
Old 10-11-2012, 12:26 PM
CameronVic's Avatar
Thanks guys, armed with this info, I should be able to start taking down 2nd gen Supras!
Old 10-11-2012, 04:23 PM
TheLS1Lover's Avatar
Better beat up some MKIVs...
Old 10-11-2012, 04:32 PM
Sales@Tick's Avatar
I was waiting for someone to say this.
This will tell you what to do not just what someone on the internet did.
Also timing isn't what makes power, it only changes when the mixture is lit.
Fuel/air mixture along with cylinder pressure and proper valve events is what makes power
Old 10-11-2012, 06:02 PM
6.0mustang's Avatar
20lbs on 25 degrees here
Quick Reply: E85 timing with boost on Gen III's?
