Broken fuel injectors!?!? PIC INSIDE
So i recently purchased a set of fuel rails and injectors from a member and he said he took them directly off of his vehicle and had no trouble with them. Upon reecieving them i noticed they were missing a few orings~ no problem i would get some new ones anyways. Upon further inspection i noticed the clip on the bottom of the injector was missing, not only is it missing on one but it is either missing or broken on all 8 of the injectors! Please take a look at the pic and tell me if i can use the injectors or if i need to get some money back. THanks
<a href="http://s760.photobucket.com/albums/xx242/k_cash1432/?action=view&current=photobucket-34544-1349901758547.jpg" target="_blank"><img src="http://i760.photobucket.com/albums/xx242/k_cash1432/photobucket-34544-1349901758547.jpg" border="0" alt="2012-10-10_14-09-42_733"></a>
With new O-rings you should be able to use the injectors, but the seller should have informed you about the condition of the injectors, and since they're all are like that I wouldn't want to attempt to run them if the way they were handled or stored looks obviously questionable.
I'd request a partial refund.
What is that little clip that is on the end of the injector Thats what im more conserned about. On the lower injcetor it is broken in half and on the upper one it is MIA! what is it, a retainer clip for the o-ring?
I have used Mr. injector for injector parts including the screens.
http://www.mrinjectorparts.com I would always use new parts when installing injectors. Parts are really cheap.
