No Dash Lights or Turnover : BCM?
Old 10-10-2012, 11:12 PM
mesterious's Avatar
Default No Dash Lights or Turnover : BCM?
My car will not crank nor will any dash lights come on. I have previously bypassed VATS, checked the two fuse box's in the engine bay for blow fuses with no luck. The fuel pump primes, AC works, blinkers work, horn works, and radio comes on, but no dash lights nor turn over. BCM make since for not turning over, but does the dash lights along with it not turning over sound like it is the BCM?
Old 10-11-2012, 07:17 AM
Ungrounded Moderator
WhiteBird00's Avatar
From your description, it is unlikely that the BCM is the problem. For one, the dash illumination has nothing to do with the BCM. For another, the radio (and windows) get all their power from the BCM and you said that is working. Also, the VATS in the BCM controls both the starter relay and the fuel enable signal to the PCM and you said the fuel pump is priming so VATS is fine as well.
I suspect you have two separate problems. Check the IP DIMMER and TAIL LPS fuses in the dash fuse panel for your illumination problem. Check the starter relay for your cranking problem.
Old 10-11-2012, 08:14 AM
mesterious's Avatar
Ok, I check both the IP dimmer and the Tail LPS and both were good. I switch the relays out as well and still no luck..
Heres a video I took:
Old 10-11-2012, 08:16 AM
Jteske88's Avatar
bad ignigtion switch? its like it only hits the accesory postition.
Old 10-11-2012, 08:36 AM
mesterious's Avatar
It could be the ignition switch.. hmmm...
Old 10-12-2012, 10:48 AM
mesterious's Avatar
Well changed the ignition switch and nothing. What else could it be?
Old 10-12-2012, 01:04 PM
mesterious's Avatar
https://ls1tech.com/forums/nitrous-o...fire-help.html
FOUND THE PROBLEM! Damn gauge fuse....
Old 10-12-2012, 01:07 PM
The GAUGES fuse has nothing to do with dash illumination... are you sure you didn't mean the warning lights weren't working?
Old 10-12-2012, 02:47 PM
mesterious's Avatar
No... All the gauges in the dash were not working.. I posted a video.
Old 08-27-2013, 11:38 AM
z28princess's Avatar
MINE IS DOING THIS EXACT SAME THING as in the video and my steering collumn is in pieces as we speak because a mechanic is trying to replace the ignition switch.. you mean to tell me that isnt going to fix it?!
Old 09-24-2013, 11:58 PM
mesterious's Avatar
Get it fixed?
Old 12-27-2013, 07:37 AM
Yessir. It was just the gauge cluster fuse. I'm sorry I didn't realize I wouldn't get a notification if someone replied
Old 12-28-2013, 10:26 PM
mesterious's Avatar
lol no problem. Well I'm glad you got it fixed!
Quick Reply: No Dash Lights or Turnover : BCM?
