lq4 into 94 camaro
lq4 into 94 camaro
So i am new to this forum and also new to LS world,
I have a 2006 LQ4 60k that Im dropping into my 94 camaro.
I plan on being in the 450 rwhp range. Just have two questions,
should I just stick with stock rod bolts, ( I might spray latter on) and also
does a 2006 ecu have the drivers to run an iac or do I need to get a ls1 or similar ecu
thanks!
thanks!
well i did in fact purchase an lq4 right now. :dunno:
i didnt start my thread to start shooting the **** with anyone.
ive searched and found out what i need to do. and now im "applying words into actions" or whatever bad grammar you decide to use
but thanks for your help
and good luck OP with your build
Here are a few references for you OP:
https://ls1tech.com/forums/conversio...on-sticky.html
https://ls1tech.com/forums/lt1-lt4-m...going-lq9.html
https://ls1tech.com/forums/conversio...dark-side.html
https://ls1tech.com/forums/conversio...-6-0-swap.html
https://ls1tech.com/forums/automatic...questions.html
https://ls1tech.com/forums/conversio...rsion-how.html
The 0411 PCM is the easiest to work with (cable driven).
