BUILT T-56/LS1/// 2 CAMARO parts cars!
Category: Drivetrain
Price: $1
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO
Location (State): GA
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
****IF YOU PM ME FOR AN ITEM PLEASE GOD PUT WHAT YOU WANT IN THE SUBJECT!!****
I've decided to part ways with all of my LS stuff.
Up for grabs:
ENGINE: 1998 LS1
140k miles on rotating assembly
KATECH ROD BOLTS: installed on the last heads/cam/intake setup I had on this motor. Never spun over 6500 and honestly hadn't been beaten on because I was about 1k miles in to breaking the engine in when I hydroplaned and totaled my SS that this engine / trans came out.
HEADS: 317 truck heads- This casting has the same flow as a 243 casting (LS6 heads) but has more material on the bottom. These heads on this engine drop the compression to roughly 9.5 to one. Heads have 41k miles on them and are stock other than the COMP CAMS 921 valve spring set (brand new in box) that goes with them.
NEW LS7 LIFTERS
NEW HEADSTUDS//// NEW GM PERFORMANCE HEADGASKETS
OIL PUMP: LS2 oil pump ported/shimmed.
OIL PAN: Modified corvette LS2 pan to fit in an S13 chassis without having to cut the front cross member.
TRANSMISSION:
5k miles BARELY past the break in stage.
I bought this transmission and decided to go through it and make it perfect before putting it in my camaro.
I ended up putting 1100 dollars in D&D PERFORMANCE parts in to this trans. It literally has everything but the viper output shaft...
Professionally rebuilt by Automotive Specialties.
I'll dig the reciept out of the filing cabinet if need be.
Comes with C6 Z06 clutch disk/ pressure plate / flywheel--with approx 6500 miles on it. When I pulled the engine trans out of the camaro the clutch looked brand new.
ACCESSORIES:
Comes with starter/ wiring harness / PCM / Alternator / harmonic balancer / intake/ MAF / all sensors including new front o2 sensors.
TRANSMISSION- 2500(I have everything for swapping an auto car--PM if interested i'll make you a deal)
ENGINE-1800 with accessories
FORD green top injectors-220
Heat sync 08 truck coils (The best coil made for LS cars)- full set with brackets- 300
LS7 clutch kit-200
white mirrors- 50
black passenger side mirror-25
manual clutch pedal assembly(I have two)- 60 a piece
LS1 aluminum driveshaft- 75
LS1 front brakes- (have 2 sets) - one set has regular rotors, one has drilled/slotted rotors with light rust on them- 100 a set OBO
4.10 gearset- (richmond I believe)- 120
Decent condition beige leath interior- 250
PRO 5.0 POWER TOWER- 125
COMP CAMS 921 NEW valve spring kit-350
HEADLIGHTS- 80(will make them look brand new for 100 total)
FOG LIGHTS- 40
tail lights- 50 (2 sets one blacked out- 1 stock)
Berger panel- 60 (one white/ one cayenne red metallic)
Convertible subframe connectors BMR- 120
I have 2 partially picked through cars so please anything you can think of msg me about and I will get back to you.
I am willing to work deals here for certain things...
ENGINE/TRANS- COMPELETE PULLOUT (longblock/trans/clutch/alternator/harmonicbalancer/tensioner/harness/PCM/fuelrail/injectors*28LB*) 4000
MANUAL SWAP-2800 (Keep in mind that's cheaper than a T56 MAG and you're getting everyything needed and a transmission with 5k miles of gentle driving)
(transmission/LS7clutchkit/stock shifter/pedals/shiftboot interior piece/rubber boot/mastercylinder)
Everything is OBO- But don't try and haggle me down on something we both know is worth more than you're trying to go for.
**** do not message me asking if I will part out things off the one complete engine I have. I won't do it. If you like the parts enough then buy the entire engine.****
