PO300 code delet???
PO300 code delet???
I put a cam in and I know it's common to have the po300 code for random misfire but is there a way to get rid of it I have a predator right now so if you know any tricks let me know
I am pretty sure you either change the RPM where it starts registering missfires to a higher level or you can delete it. I think you will need LS1-edit though for either method.
you can change the Low RPM misfire detection with LS1-edit to 32000 microseconds.
