Backwards. <430 fwhp LS1 FI
Hi,
Been searching around but can't find an answer to my perhaps a little strange question.
I live in Sweden and this winter I'm swapping a LS1 t56 combo into my corvette 1969. I've dreamt of this for a long time and now it's finally happening. The swap itself will be a lot of work and when that all is done there will be alot of work getting the car road legal with the new engine. The restrictions lies in power and I'm not allowed to make more then 430 fwhp, will have to be dyno proven.
As I'm going through all of this I'm thinking about supercharging the engine already from the start so that I'll have all the mods in the new title.
My question is if it's possible to get the engine with a supercharger (needs to be at "reasonable" boost (according to law), say 6-8 psi) to perform less then 430 fwhp. Would like to have an intercooler in there too if possible. All stock healthy 02 camaro ls1 with stock f-body exhaust manifolds, no cats.
Once all the paperwork is in order the tune can be changed and the boost can be upped as it will never have to be dynoed again for the yearly inspections.
Thanks
//Axel from Sweden
Thanks
//Axel from Sweden
So it should be possible? 6 pounds of boost, some restrictive timing and a not to open exhaust would put me under 430 fwhp on a stock ls1?
430 fwhp is increadibly around here. If the car is newer then 1975 your not allowed to do anything (FI is out of question) and pre 1975 the usual is around 200 fwhp. Corvette pre 71 is the real exception when that much power is allowed here!
Then ofcourse we have a huge amount of people driving around putting turbos on after inpection every year and a great deal driving not legaly uninspected. Fines are small and there is no real problem driving not legal untill **** hits the fan and your insurance wont cover because you were not inspected.
Thanks for all the quick answers
rev limits not allowed. Have to see that power is peaking on the dyno graph and boost has too be set reasonably according to the equipment used. Ex: can't have a huge turbo, dual A1000 and 160# injectors and boost 3 psi.
But I can have some stock injectors, a 255lph pump and a stock exhaust a charge 6 psi from a base model vortech supercharger
As I said before lowering the boost too much wont really help me as it needs to be boosted reasonably given the things that are on it. Need to get that power <430 without going under 5psi (VERY LOWEST) or using rev limiters.
The new paperwork will be about $300 inspection fees + $200 admin fees and about $300 for the dyno (expensive dynoshops as there are only a few in the country licensed by the goverment to make approved power verifications).
The goverment doesn't really check everything but the dyno shops are very careful with their license and won't let you pass with any cheap work-arounds.
Seems a bit easier in the states.
The 2 main reasons for a supercharger compared to a H/C swap would be:
1. Can turn boost up the day I want moore. The 430 is just to get the supercharger into the paperwork.
2. Keep my fuel economy when staying of it on long trips. Gas is currently $9.2/US gallon here and rising.
Am I thinking badly?
Yupp. If I buy the supercharger, mount it, put a restrictive exhaust on it and make a real lousy tune and still get 430 fwhp I'm "screwed". Can always take it all off and sell it but wanted to get some opinions from guys having alot more dyno/tuning time then me to see how far down I could push numbers with the same boost but a lousy tune.
