What starter???
Old 10-17-2012, 01:02 PM
1970 LSCamaro's Avatar
Default What starter???
I need a little help...new to the whole swap thing. I have a 2001 LS6.0 motor wirh a LS7 flywheel.....do I nee a truck starter, or a camaro starter? Hope this isn't a dumb question...thanks guys.
Old 10-18-2012, 05:49 AM
Anyone?????
Old 10-18-2012, 07:02 AM
Pop N Wood's Avatar
Always hard to get definitive answers about starters.
Old 10-18-2012, 07:27 AM
garys 68's Avatar
Since it's an 01 6.0 I'll assume it's an iron block.
Just order the starter for the motor. The truck starters are smaller and have 2 thick bolt mounts (less likely to brake).
Old 10-18-2012, 11:26 AM
badazz81z28's Avatar
Starter is the same for all LS engines. If you look up the application for a starter for a 2001 corvette at Rock-auto.com, Look for the one with a heart next to it. The application will show a butt load of applications. LS1/LS2/LQ4/LQ9 etc..Its the 2 long bolt starter. Its not what came stock on the LS1 (visually), but works.
They are the same size...I have both starters.
Old 10-18-2012, 12:04 PM
85MikeTPI's Avatar
https://ls1tech.com/forums/conversio...ter-swaps.html
The 2010 LS3 Camaro starter is a nice inexpensive alternative for a real Delco, 2-long bolt starter.
Old 10-18-2012, 04:04 PM
BOXCHEV's Avatar
That's what I bought
Old 10-18-2012, 05:52 PM
brewster240's Avatar
no they arent, and i learned this after being told they were the same.
gto starter and fbody are different than each other and will not interchange.
Old 10-18-2012, 06:40 PM
stereojnky's Avatar
I was told that the gto bell housing notch was too small for the fbody starter but the gto starter would work with the fbody bell.
Is there a starter stickie somewhere?
Old 10-18-2012, 06:52 PM
that may be true.
ill check again, i have both here, have to change the starter on one soon anyway.
Old 10-18-2012, 07:28 PM
Who said anything about a GTO?
I thought this was a conversion swap?
http://www.rockauto.com/catalog/raframecatalog.php
I just bought the Pure Energy and its the same size as the 2002 LS1 starter
Old 10-18-2012, 07:31 PM
gto have an ls, and they use a starter.
you said all ls starter are the same. they are not.
Old 10-18-2012, 08:18 PM
I did....What I meant was the engine itself. I had no idea the GTO had a special starter.
Old 10-18-2012, 10:37 PM
stereojnky's Avatar
IIRC it's a Mitsubishi starter and smaller than the others.
Old 10-19-2012, 06:26 AM
Ok...I will mix this up a bit....My block is a iron block 6.0, it has a LS7 flywheel, and I just bought a T56 out of a 2006 GTO. Sooooo with all the discussion here......what starter do I need? lol
Old 10-19-2012, 06:54 AM
Pop N Wood's Avatar
Originally Posted by pop n wood
always hard to get definitive answers about starters.
lol....
Old 10-19-2012, 07:35 AM
garys 68's Avatar
You'll need a GTO flywheel/clutch, then use the GTO starter (pretty sure it will fit).
Or you might be able to use an f body bell on the GTO trans with the LS7 flywheel, and truck starter. You might want to confirm this combo in the manual trans section.
Old 10-19-2012, 08:02 AM
Doug G's Avatar
Locally I couldn't find one under $200 ( with core charge)....Found one at Summit for $129 TMD.
It said for a 2004 Silverado which is the motor I have.
http://www.summitracing.com/parts/TFF-6492B/
Old 10-19-2012, 08:45 AM
Brand new from J.C Whitney or Rock-auto.com...$92
Look up 2001 Corvette, its the one with the heart next to it. No Core charge. Just make sure you buy a set of bolts, it only comes with 1 and its not knurld
Quick Reply: What starter???
