What welding machine do you use?
I've used Lincoln, Miller, Hobart, and Snap-on. It really just depends on what you'll be using it on. Size material? Aluminum? Seal welds? All have been good machines and had pros and cons.
i have a lincoln 180. its 220 volt but i planned for that when i built my shop. it is almost too big for small interior patch panels that im working on right now, but i can manage and im no welder by any means. it is nice to be able to weld 1/4" or larger plate and tubing when i need to without having to bevel too much. gets really good heat penetration.
I have a Hobart 140 handler. Its a 110v machine and was around $550-600 from Northern. Its great for small to medium thickness work. I built my complete turbo kit with it subframe connectors, cages, etc. I have it set up with solid .030 wire. I also have a miller 250 dial arc hf tig machine that I just got. Between the two I have the best of both worlds.
I'm about to buy a machine too. Really leaning toward a Thermal Arc Fabricator 181i or 211i. They are Mig/Tig/Stick capable. 99% of what I'll do is mig but I like the idea of having all three in one.
