Window/ door issues.
I bought a donor door for my T/A after an accident. The numnut who did the body work on my car hooked the electronics up wrong and my window switches for that door wouldn't work.
So I took it apart today to swap lock cylinders and troubleshoot, I hooked the wiring up correctly and got the window to work.
Problem 1- When the window reaches the full range of motion up or down, the motor doesn't shut off. It'll keep going and want to bend the inner door panel which is flimsy fiberglass I have these 2 little plugs that I'm not sure where they go.
Problem 2- The glass in that door rattles and drives me crazy. I tightened up all the screws and got most of it but there is 1 thats left. Its for the window track and has no slot in the head on it, I can't grab it with anything so it wont spin. Suggestions?
Save the manuals!
Did they pull your original wiring back in to the dash and then thread it through the new door? Or did they splice the donor door's harness in?
Those plugs are definitely for something aftermarket, as are the wires attached to them. You will probably want to trace those back to their source.
I'm not sure what the issue is with #2. You should be able to put a 10mm socket on that nut and tighten it. The bolt is permanently attached to the track.
I see no evidence of them splicing anything, but will know for sure when I take apart the area under the steering column to fix how the fog light switch mounts.
What is it thats supposed to stop the motor when it reaches it's full range of motion though? It'll keep going and want to bend the door frame.
The issue with #2 is that the head of that bolt has come apart from the window track and spins as the nut spins. I'll jbweld it and hope it holds enough for me to tighten it up.
Also last night the wires for the windows came apart and shorted (the shop broke the plastic retainer) as I was closing the door. The window switches on the D/S no longer work, I'm going to assume it popped a fuse?
Save the manuals!
The bending of the door panel is normal. They all do it and the panel will bend before the thermal cutoff does its thing. Are you sure that the cutoff isn't working or are you just concerned with the bending? On the driver's side, the express down module will continue to provide power to the motor; (so you'll see power continuing at the connector) however the motor should be cutting off internally.
I'd suggest taking the door covering off on your passenger side and comparing the two. That should give you a good idea of what is normal and what isn't.
Yes, its probably a fuse. The plastic retainer that holds the wires with the pin-grip terminals on them doesn't lock tightly. Even from the factory, there was electrical tape installed around them to keep the connectors shut so the wires don't move around.
In that case the circuit is not being cut, the motor will keep going regardless of resistance.
There is only 1 provision for the windows in the fuse box and that is a breaker. Its a Wagner 30A 12V. Doesn't look like local stores have it so I'll have to order it.
Hopefully its this and not the RAP module.
Thanks so much for taking the time to help!
Save the manuals!
If your motor runs, your breaker and RAP module are perfectly fine.
I don't think you read my last post correctly. I'm pretty sure your motor IS cutting off. What are you using to make your assessment that it is not cutting off? (If you are using the door bulge as the test - you can't do that. The bulge is normal.)
The motor doesn't cut off because it will keep going and over extend. It goes out farther than it should and lower than it should way past the dew wipes. It goes up past the rubber triangle by the mirror and the glass doesn't seal against the door seal now, I'm not sure how to wind it back down manually so it seals properly until I can get the windows working again.
I took the breaker out and the metal cover off. Not exactly sure what its supposed to look like, but I see no evidence of it being fouled.
Save the manuals!
This can not be done easily. I'd suggest jumping 12V to the motor and manually move the glass up and down that way.
I swapped breakers today and no change.
I can't find a pic or description anywhere of the orientation of the wires into the retainer/ window switch.
However it has to be something deeper in the system. Heres why:
When I initially picked the car up, I was told the D/S window wont work because the wiring is served somewhere. However the P/S was working fine with it's switch.
Fast forward to when I hooked up the D/S properly and it all shorted, now none of the switches work including the P/S. So something got fried and it wasn't the breaker because I swapped it with the one for the defrost/ seats 30A and still nothing.
Save the manuals!
You can't say this without getting an electrical tester and testing stuff. At this point, with potentially severed wires (if there was really a sever, I'm not sure how you could get it working before the short), a recent short circuit, and potentially misplaced switch wires, everything you do is just a wild *** guess - unless you have a tester and a schematic.
