Transmission Crossmember won't line up
Old 10-19-2012, 09:49 AM
WS.666's Avatar
Default Transmission Crossmember won't line up
Long story short, my 2000 Trans Am got wrecked and I'm swapping everything over to a 1994 Firebird body. Last night, I was finally getting the motor into the body and as I'm bolting everything up, I noticed this:
The passenger side lines up and bolts up fine, but the driver side is easily 6 inches off. Were there differences in the bodies for the early 4th gens? Everything else on the car is identical to my 2000, and this is the first difference I have found. How would you all go about fixing this? Fabricate an adapter?
Old 10-19-2012, 12:48 PM
trans_am7935's Avatar
the LT1 body and the LS1 body use different mounting points for the transmission crossmember, you will need an LT1 style one. the t-56 LT1 and LS1 have the same mounting point on the transmission, but i don't know about the auto ones
Old 10-19-2012, 04:07 PM
WS.666's Avatar
I have a T56, so all I need is a LT1 T56 cross member?
Old 10-19-2012, 04:11 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
You are correct, the Lt1 cars and LS1 cars have a little different floorboards so you need make sure you use a T56 crossmember from an LT1 car (93-97) and everything should line up.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 10-19-2012, 06:55 PM
Spartan7's Avatar
Yep, get yourself a 93-97 crossmember and all will be good. I have an LT1 in a 98+ car and had to do just the opposite.
Quick Reply: Transmission Crossmember won't line up
