HP limit of Eagle Rods?
I have a set of Eagle rods I'm going to be using in my new engine. They have the ARP 8740 Chrome Molley rod bolts in them now.
Does anyone have an idea of these rods HP limit?
Would I gain anything having ARP L-19 bolts installed? Would I need to resize/rehone if I change rod bolts?
turbo stang
I can shift faster than you.
I would highly recommend the L19 bolts. I would also have your machinist check the housing bore of the rods regardless, especially if the bolts are changed. Eagles rods are good rods for the money, but they do need to checked out of the box prior to assembly.
